AppleTV Renderers - Infuse 5 or alternative
Post by infinityends » Fri Jan 19, 2018 4:47 pm
I'm curious what apps people use with UMS on AppleTV?
I've used VLC in the past and it is painful.
I've been using Infuse 5 but somewhere between the switch to infuse 5 from infuse 4 and UMS 6.5.X I started having issues with UMS crashing and then i have to delete and reconnect the share in Infuse for it to work properly.
I'm wondering if there is something other than Infuse I should try? there dont appear to be any official renderers for appletv beyond vlc.
I know I probably need to enable logging on UMS to figure out what is going on, not sure if im hitting a memory cap causing the crash, the system has plenty of ram to offer though.
