Apple TV + VLC
tangles
Apple TV + VLC
Post by tangles » Sun Jun 24, 2018 11:43 pm
I have an old-ish Sony BRAVIA (HX-750) which works OK with UMS except for large video files. I recently installed the VLC app on my Apple TV device and it handles large files with no problems.
There are a couple of minor issues, however:
1. It is very slow to load large file directories. I don't know if this is a problem with UMS or the VLC app. I will try splitting my file directories into smaller subdirectories.
2. The VLC app appears on the UMS main panel as "unknown renderer". Is there a configuration file for this app?
valib
Re: Apple TV + VLC
Post by valib » Tue Jun 26, 2018 9:36 am
What is the problem with the large video files? Can you send the log to see what happened? It is a VLC problem to be very slow because of the bad DLNA implementation.
tangles
Re: Apple TV + VLC
Post by tangles » Fri Jun 29, 2018 11:16 pm
There is no problem with large video files and Apple TV. The problem occurred with UMS connected directly to my BRAVIA TV.
Apple TV is slow to load large DIRECTORIES. I don't know if this is an Apple TV or UMS issue.
The Apple TV shows up on the UMS main panel as "unknown renderer". Any suggestions?
