Philips TV render
aecordoba
Philips TV render
Post by aecordoba »
Please, I need the right render conf file for the 42PFL5008G/77 model of Philips Smart TV.
(I'm using UMS 3.3.0)
Thank you in advance.
Adrián E. Córdoba
Adrián E. Córdoba
leroy
Re: Philips TV render
Post by leroy »
To get the ball rolling, you need to post some info.
Provide a debug.log for the user-agent string sends from this tv:
How to ask for support
Provide the ProtocolInfo:
HOWTO - Device Spy - What your Renderer can really use
The FAQ describes how to create a custom renderer.conf:
My device is not supported by UMS. How can I create a custom renderer.conf to make UMS recognize my device?
Here is the 42PFL5008G/77 user manual which provide the supported codec table.
Schukkie
Post by Schukkie »
Hallo Leroy,
je heb een tijdje geleden een conf voor een philips pfl 9705 gemaakt deze ben ik kwijt, kun je deze nogmaals op het forum plaatsen.Het forum van PS3mediaserver werkt niet meer, dank je
Sami32
Post by Sami32 »
Try that one:
https://raw.githubusercontent.com/Unive ... s-PFL.conf
If it doesn't work, just follow the steps that @leroy already mentioned, as stipuled in the forum rules write in red here: viewtopic.php?f=3&t=556
