New renderer Yamaha-RXV500D
newbietux
Contact:
Post by newbietux »
I'm created the renderer-file for Yamaha Receiver RX-V500D based on the Yamaha-RXV3900 file.
I could'nt test the aac and wma options.
Yamaha-RXV500D.conf
(1.26 KiB) Downloaded 600 times
radamo
Re: New renderer Yamaha-RXV500D
Post by radamo »
newbietux wrote:I'm created the renderer-file for Yamaha Receiver RX-V500D based on the Yamaha-RXV3900 file.
Yamaha-RX-A2050.conf
(1.35 KiB) Downloaded 499 times
Thanks, I used this to update my RX-A2050 config. Now seems to work properly. I did not add in the "TranscodeAudio" line in my config. Everything I have in my collection are "Apple Lossless". When using Windows Media Player to stream I see "Apple Lossless" on the Yamaha display. When using UMS I see PCM. Wondering if I can figure out how to stream Apple Lossless direct???
Thanks for this, it will be in our next release
newbietux
Contact:
Post by newbietux »
I had updated my
Yamaha-RXV500D.conf
Yamaha-RXV500D.conf
(1.26 KiB) Downloaded 517 times
because the first version functions not so good as I want.
Now when I stream FLAC- or WAV-files with the updated renderer file the result is that the Receiver displays "UNKNOWN" and use then the FLAC- or the WAV-Decoder do decode it. That is not the best what I want but I don't find a way to make, that the receiver recognize the FLAC-Format.
If the receiver displayed the PCM then had the UMS transcoded the files to PCM. That is not what I want.
On the base of inspection the receiver functions with the "DeveloperToolsForUPnPTechnologies" I think that the receiver can not recognize the FLAC- or WAV-Format on the basis of construction the DLNA-part.
This is the most important part of the log-files from the tool:
http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM,
http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMABASE,
http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMAFULL,http-wavetunes:*:audio/x-ms-wma:*
Please inspect or test the updated renderer-file to confirm my results. If your tests arr positiv you use the updated renderer-file.
