Need YAMAHA RX- A720 renderer
jp0213x
Post by jp0213x »
Need a rendered for a Yamaha rx-a720.
jp0213x
Re: Need YAMAHA RX- A720 renderer
Post by jp0213x »
No luck with this render for me, unable to play radio streams and No icon for receiver shows up in UMS. Phillips streamium renderer seem to override Yamaha icon.
Sami32
Post by Sami32 »
No sure what you mean, as i never used radio streams, and this is not handled in this renderer configuration file, AFAIK. So i'm not able to help you on that matter.
Yes, you got an error so it used the Panasonic TV renderer :
DEBUG 22:54:54.601 [cling-14] Error initializing device yahama: java.lang.NullPointerException
INFO 22:54:54.601 [cling-14] java.lang.NullPointerException
INFO 22:54:54.601 [cling-14] at net.pms.newgui.StatusTab$RendererItem.<init>(StatusTab.java:69)
That's because you are using an old buggy UMS version, which do not handle correctly your renderer icon, try with a more recent version and everything should be fine ;)
This bug was fixed by @Skeptical around 2 years ago...
The only purpose of this renderer is to make you able to play all standard audio files supported officially by your renderer (AAC, MP3, WAV, FLAC, WMA) and transcode the others format.
jp0213x
Post by jp0213x »
thanks
jp0213x
Post by jp0213x »
Sorry man I am still using 5.3.1, I would have to upgrade. If you create a render for my other yahama post, I can leave feed back. My friend has a newer yamaha model and they are using the latest version UMS. I am helping them with the setup.
jp0213x
Post by jp0213x »
Sami32 wrote:I need feedback 8-)
Here are the logs from 6.60. There is a problem with radio station play back from my web radio config. Flac files were able to play.
Sami32
Post by Sami32 »
Could you be more precise ? What kind of problem ? You tried all the others audio format and only FLAC worked from your web radio ?
I'm not familiar with Web radio, and as i said it's not handled by the renderer configuration file.
Do all the audio files (AAC, MP3, WAV, FLAC, WMA) played correctly from your PC ? (i mean not from the Web radio)
After that, i could look at your log with a better idea of what to search for...
