Need YAMAHA RX- A720 renderer
Re: Need YAMAHA RX- A720 renderer
Until i get time to check at your log, you can try different UMS version and identify the latest that work for you:
https://sourceforge.net/projects/unimed ... s/Windows/
I will roll back to to 5.13, everything works with this version.
I only used the radio with UMS 5.13 and 5.2.2. I would still be on 5.2 but there was some sync problems. 5.1.3 is the most stable for me. Its a crap shoot with different version UMS because you never know what you will get.Sami32 wrote:And how it's work with 5.1.4 ? 5.2.0 ? 5.3.0...?
Perhaps 6.5.0 could work better.
5.5.0 version was very stable as well.
If I recall I started to run into problems starting with 5.50 or testing a lower version of 6. I had a problem with ts video files. TS videos not populating in some of my tv folders. Problem appears to be fixed with 6.0. but other things are broken with 6.0
What's happen if you force the Stremium renderer with UMS 6.6.0 ? (if you don't know how to force it, just delete the Yamaha-RXA720 renderer)
Does it make any difference while playing your Web radios ?
The radio stations are greyed out, when I browse to my list through my Yamaha.Sami32 wrote:What's happen if you force the Stremium renderer with UMS 6.6.0 ? (if you don't know how to force it, just delete the Yamaha-RXA720 renderer)
- ums_dbg6.60A720V3.zip
- (63.64 KiB) Downloaded 467 times
Just for the hell of it here is the log with 5.50, radio works but brings other problems.
https://workupload.com/file/8Nq3bhV
jp0213x wrote:Just for the hell of it here is the log with 5.50, radio works but brings other problems.
