PS4 Pro compatible?
OhIGetIt
PS4 Pro compatible?
Post by OhIGetIt »
Hi, just purchased a Pro but can't get UMS to recognise it. Do I have to make a custom renderer or is UMS just not compatible with the Pro?
Edit: Got it working, you have to select the "Media Player" in the PS4 menu to get it going.
Sami32
Re: PS4 Pro compatible?
Post by Sami32 »
Actually a PS4 Pro render has been done but never pushed, as no users returned feedback.
Sadly, most of the time, feedback is only given when things get wrong...
If you want help us improve UMS, you can test it and return feedback: (Add/replace this file in your "renderers" UMS subfolder)
https://raw.githubusercontent.com/Unive ... tion4.conf
You'll just need to test 10-bit videos and video having external SubRip (SRT) subtitle and tell us if it work as expected.
If not, post a full trace log, as explained if you click on the red link in my signature below, will be welcome ;)
