infidel
Re: Jumpy Plugin (11 November 2014)
Post by infidel »
Rasmnev wrote:I'm quite new at this. I just tried to install jumpy, and everything seems fine but when I open the jumpy folder on my ps3 all I get are 3 empty folders. Am I supposed to install anything on my ps3 to get this to work?
Hi Rasmnev, need a little more info to give you a meaningful response :). Please attach a set of TRACE logs showing navigation into the empty folders, plus the file plugins\jumpy\setup\setup.log.
nickhere
Post by nickhere »
Jumpy Need UPDATE TO Reflect name change and path
xmbc to kodi
infidel
Re: Jumpy Plugin (23 January 2015 - Kodi update)
Post by infidel »
nickhere wrote:Jumpy Need UPDATE TO Reflect name change and path
xmbc to kodi
thx, see below: :)
infidel
Post by infidel »
nickhere
Post by nickhere »
not sure how to install it.
all i have installed now is a clean install of ums 5.00 and Kodi all set up
infidel
Post by infidel »
nickhere wrote:not sure how to install it.
in that case:
  • install jumpy (and cancel the xbmc installer when it pops up).
  • unzip the update to plugins/jumpy in your UMS program folder.
nickhere
Post by nickhere »
thank you now if we can get all the ums problems fixed i can become a fat couch potato. Then i have you to blame :)
h8spaCec4EspUdE
Post by h8spaCec4EspUdE »
Please help.
kodi
I cannot find urlresolver addon for kodi and jumpy keeps saying update available while the description says urlresolver and youtube are required to be installed first.
ums
If there is no urlresolver in kodi, how should I set the ums jumpy gui about resolver priority(e.g. 1,2)?
infidel
Post by infidel »
h8spaCec4EspUdE wrote:I cannot find urlresolver addon for kodi
The gotham version of urlresolver still works, I think. youtube-dl is actually the better (i.e. more useful) resolver, so you're not missing much even if you skip urlresolver.
h8spaCec4EspUdE wrote:jumpy keeps saying update available while the description says urlresolver and youtube are required to be installed first
You can disable/remove the jumpy addon from kodi to get rid of this behavior. You're fine as long as plugin.video.youtube remains installed.
h8spaCec4EspUdE wrote:If there is no urlresolver in kodi, how should I set the ums jumpy gui about resolver priority(e.g. 1,2)?
It doesn't matter, since it will default to youtube-dl anyway, but set youtube-dl=1 if you want to shave off a few nanoseconds :).
h8spaCec4EspUdE
thx for help and the great plugin :lol:
