Re: Jumpy Plugin (19 Nov 2012)
Hi again,
Okay I've attached my log. One thing I notice now is when I don't have a l/p setup on Vimeo, but I do on Youtube and niether are working properly. Also, when I initially click on the subscriptions folder (for YouTube) I get a (DNLA 2006) error, but then when I try it again (after going back to the original jumpy folder and then back to the YT sub folder) it will list the directories. The main problem is that none of the files will show up. All I get is "Add Bookmark" option. Thanks again for taking the time to help.
kurou
kurou
- jumpy.zip
- jumpy.log
- (6.65 KiB) Downloaded 1090 times
Thanks for the log, kurou, much easier
which is fixed by replacing plugins/jumpy/xbmc/xbmcaddon.py with this one:
[attachment removed] - superceded by jumpy-0.2.5
The puzzling part was that I couldn't reproduce the error initially in linux since for some reason no 'login-cookie' was being used, but I switched to Windows and bingo. It's not clear whether unescaping every single setting (which is my fix) could cause problems elsewhere but we'll see I guess.
The actual error is pretty straightforward, the 'login-cookie' setting was html-escaped and needed to be unescaped.kuroukage wrote:The main problem is that none of the files will show up. All I get is "Add Bookmark" option.
File "<string>", line 1
{'APISID': u'X3YJ ...
Apparently caused by slow response / too many files on the PS3, see here. A similar thing happens with large directories on my Sony Bluray, i.e. the files show up only when you re-enter.kuroukage wrote:Also, when I initially click on the subscriptions folder (for YouTube) I get a (DNLA 2006) error, but then when I try it again (after going back to the original jumpy folder and then back to the YT sub folder) it will list the directories.
Awesome, thanks for everything. Works now. So far I haven't run into any problems using any other addon. When do you plan on releasing a new version of Jumpy?
Soon as you guys take a break from finding bugs. I was all set to release a few days agokuroukage wrote:When do you plan on releasing a new version of Jumpy?
I can help you find more bugs if you'd like. There's sure to be some with XBMC 12 final build coming out soon and they have a ton of video addons.infidel wrote:Soon as you guys take a break from finding bugs. I was all set to release a few days agokuroukage wrote:When do you plan on releasing a new version of Jumpy?.
Hi
This is my first post.
I am trying to run a xbmc video addon (tvalacarta) into PMS.
The first problem I have found is installing rtmpdump...
From the setup.log:
Could you please help me??
Thanks in advance
From the setup.log:
Where "El sistema no puede hallar el archivo especificado" means "the system cannot find the specific file"Checking rtmpdump
Installing rtmpdump
Downloading "https://github.com/downloads/K-S-V/Scri ... mp-2.4.zip"
Download error
El sistema no puede hallar el archivo especificado.
unzip: cannot find either rtmpdump-2.4.zip or rtmpdump-2.4.zip.zip.
Checking rtmpdump
Warning: problem installing rtmpdump \nsee D:\\UNIVER~1\\plugins\\jumpy\\win32-setup\\setup.log
backing up and replacing UMS.conf
done
Error: some items were not installed.
Thanks in advance
First problem solved by my own...frentemorao wrote:Hi
From the setup.log:Where "El sistema no puede hallar el archivo especificado" means "the system cannot find the specific file"Checking rtmpdump
Installing rtmpdump
Download error
Checking rtmpdump
done
Thanks in advance
I just download rtmpdump.zip from the link showed in the setup.log and copied it into the win32-setup folder...
Second problem "no items/elements to show" on my Bravia...
Excellentfrentemorao wrote:First problem solved by my own...
For the second problem, replace plugins/jumpy/xbmc/xbmcaddon.py with this one:
It solves the specific problem and some items are working, but please note that many items don't play inside xbmc itself with this addon, so naturally they won't in jumpy either. Attach a log if some work in xbmc but not in jumpy.
Second problem solved. Thank you very much for you quick answer --> for my curiosity, what are the main differences between both files (new and old)?infidel wrote:Excellentfrentemorao wrote:First problem solved by my own...!
However, this solution does not work for the other spanish xbmc video addon (pelisalacarta)...
Infidel, any idea for running pelisalacarta addon?? (let's say this is my third problem...)
infidel wrote:It solves the specific problem and some items are working, but please note that many items don't play inside xbmc itself with this addon, so naturally they won't in jumpy either. Attach a log if some work in xbmc but not in jumpy.
Fourth problem... I have tried to play channel "mitele" unsuccessfully (it works in xbmc correctly).
Specifically I have tried to watch a Tv Show called "La que se avecina" as you can see in the log attached: Nothing appears except for the "Add Bookmark" item...
Something similar happens to me with channel "rtve" (for example, with the Tv Show called "Cuéntame cómo pasó") and also with the tv shows from the icefilms xbmc addon (curiously I can see several movies from this addon on my Bravia...) and all of the videos of the sportdevils addon...
Case-insensitivity. In the old one tvalacarta asked jumpy for the value of 'Path', which jumpy couldn't find because its variable is called 'path'.frentemorao wrote:Second problem solved. Thank you very much for you quick answer --> for my curiosity, what are the main differences between both files (new and old)?
It's working for me, but you may need to:frentemorao wrote:Fourth problem... I have tried to play channel "mitele" unsuccessfully (it works in xbmc correctly).
- update your tvalacarta to version 3.3.5.
- update the rest of your jumpy-xbmc files (sorry, I should have posted all of them
frentemorao wrote:Something similar happens to me with...
- icefilms: should work after "Fourth problem" fix.
- rtve, sportsdevil: haven't checked, but see if still problematic after "Fourth problem" fix.
- peliculasalacarta: use the latest version. For me most of it doesn't work, whether in xbmc or jumpy. I'll look into it more later.
