Re: Jumpy Plugin (26 February 2016)
I hear you -- there are times where i have to scroll to the bottom of the lists to get a source to stream while in Kodi... So jumpy uses the first source regardless then... noted..infidel wrote: There are several issues with this addon that make it a bad candidate for jumpy/ums use:
- like all the source-aggregating addons it takes a lot of time scraping various sites/file-servers, so often ums times out waiting for a stream while the addon is still busy finding sources. Whether you get a link in time is hit-or-miss, I was able to get one TV show to work on the 3rd attempt.
- Since there's no consistency as to sources, there's no guarantee that playback will work consistently either, i.e. just because it works for one item doesn't mean it'll work for another.
- It presents a dialog of sources to choose from. Since there's no such thing as a dialog in DLNA, jumpy automatically picks the first item in this situation, which may or may not be a good choice, and all the other sources are ignored. Some of the other aggregators populate a folder with sources, which works better in jumpy, since you can browse through and try them one by one.
Yeah i ended up allowing python to access OUTBOUND in malwarebytes... thought it was strange... we'll see how that pans out.infidel wrote:Well I have no idea on this other than it has to do with trying to stream from a questionable source, but I take it you're saying if you play the same link via another renderer (or directly in kodi itself) Malwarebytes doesn't complain?
Universal Media Server Wiki!
DeFlanko wrote:
- Youtube in Kodi does not work in Web Interface through Jumpy.
- Youtube in the Web Interface did not require me to youtube/active.
- Assuming the activation is a one-time thing, it shouldn't be required when you're using jumpy as long as you've already done it previously in Kodi. The addon should read its login settings when running under jumpy, same as when it's running under kodi. One thing to try is a ums session with kodi not running. Lately I've seen a 'locked database' error sometimes when both kodi and jumpy are running at the same time (i.e. jumpy wasn't able to open the db because it was already open in kodi). Generally jumpy and kodi are able to share dbs but something may be different here, will look into it.
- As previously mentioned there's no such thing as a dialog in DLNA, so you would never see any login dialog in ums anyway.
Re: Jumpy Plugin (21 February 2016)
good info thanks infidelinfidel wrote:Looks like it may be due to the ffmpeg binary. I just tested twitch in Windows and it wouldn't work until I replaced win32\ffmpeg64.exe with the latest zeranoe.com build. Try swapping+renaming binaries, or point ums to the preferred one in UMS.conf, e.g:kuroukage wrote:\ffmpeg64.exe" has a return code of 1!If you still have issues, post a full set of logs reproducing the failure.Code: Select all
ffmpeg_path = C:\\Program Files (x86)\\Universal Media Server\\win32\\ffmpeg-zeranoe.exe
i was having trouble starting (watching) a live show on twitch, getting the dreaded stopped + "ffmpeg returned error of 1 check the log"
I updated to latest ffmpeg and it works now.
This needs to be in a FAQ/Sticky somewhere
Win 10 64bits
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my own conf)
Perhaps, but the bug was introduced into ffmpeg source code on Jan 16 and fixed on Jan 31, so it only applies to ffmpeg builds between those 2 dates, i.e. only for current UMS package. Next one should be fineHT1 wrote:I updated to latest ffmpeg and it works now.
Fixed on jan 31st but not in ums, 2 months ago and the devs didn't update it until i brought it up in the 6.20 release thread.infidel wrote:Perhaps, but the bug was introduced into ffmpeg source code on Jan 16 and fixed on Jan 31, so it only applies to ffmpeg builds between those 2 dates, i.e. only for current UMS package. Next one should be fineHT1 wrote:I updated to latest ffmpeg and it works now.
This needs to be in a FAQ/Sticky somewhere.
Might be an oversight, but it's not trivial, it is the basis for ums to work with video files. its set as #1 decoder, i wouldn't call it trivial.
Actually if memory serves (and it does), it's not the 1st time in my 2 years of using ums that i've had to update ffmpeg manually for ums.
And each time was sufficiently long apart that i actually forgot what the fix was, which means having to search for it high and low since its not anywhere.
Maybe this should be in the plugins tab. it's a quick way to check if ffmpeg is upto date and simple to update.
Win 10 64bits
Quick Q: Does this work with Kodi Jarvis?
jumpy-xbmc version 0.3.16
special://xbmc=C:\Program Files (x86)\KODI
special://home=C:\Users\******\AppData\Roaming\KODI
home=C:\ProgramData\UMS\Plugins\jumpy\xbmc
[jumpy] PROFILEDIR : C:\ProgramData\UMS\jumpy
[jumpy] setEnv: remove 'force_resolve'
found xbmc addons dir at 'C:\Users\******\AppData\Roaming\KODI\addons'.
Error: required addon not found: script.module.pyxbmctmanager
Quick A: yes, but as always there could be specific addon issues.glenrocks wrote:Quick Q: Does this work with Kodi Jarvis?
I been using Jumpy with success with my old plugin.
The only thing back then (kodi 14.x) was that I had to add 'file' atribute to url and it would look like this:
And thanks to that I could navigate thru my plugin and watch videos from my stream server.
It's been some time now (Kodi 16.1), but Jumpy give me error because he is trying to open file that have url:
This is of course when I navigate thru menus from my plugin (which apparently works ok)
It looks like he is trying to open file from UMS (I understand that Jumpy grabbed (or not) file from my url, pass it to UMS an UMS is trying to transcode it but without success). Im unsure if Jumpy grab file= or full url or just the RestApi part.
Do I have to do something else to make Jumpy once again support in my plugin? Did anything change ? or this is UMS related error ? (im using 6.3.1 and 6.3.1.1)
Info that could be helpful:
- In UMS logs I see "jumpy: [resolver] registering com.sun.proxy.$Proxy2"
- also in Jumpy-log I see this: import os.path ImportError: No module named path [jumpy] latest version is 0.3.9b but my Python 2.7.11 have os.path and use it without problems
- im using latest stable Jumpy 0.3.9b on Windows x64 with python 32bit and I didnt change any option except print to log
run_addon: plugin://plugin.video.my_plugin/?url=http://127.0.0.1:8111/RestApi/GetInfo/0/7/16224&mode=1&file=http://127.0.0.1:8112/videolocal/0/16224/file.avi&ep_id=15193
http://192.168.0.2:5001/get/105/The+Girl+Of+Snow
server: C2D [email protected] 3GB RAM
network: wired 1000MB/s
OS: Linux 13.10 64bit
Hi, not enough infosapsa wrote:Do I have to do something else to make Jumpy once again support in my plugin? Did anything change ? or this is UMS related error ?
If you say you need it then ok.infidel wrote:Hi, not enough infosapsa wrote:Do I have to do something else to make Jumpy once again support in my plugin? Did anything change ? or this is UMS related error ?. Without seeing a full set of logs and source code of plugin.video.my_plugin I can't help you very much.
https://github.com/bigretromike/nakamori/
Logs are in attachments
- ums_dbg.7z
- (50.05 KiB) Downloaded 1003 times
