Version 7.2.0 released
Post by SubJunk » Fri Jul 27, 2018 3:49 pm
General:
This release improves the automatic updater, memory usage, database size, fixes many bugs and more!
Changes since 7.1.0:
  • General:
    • Auto-updater no longer requires UMS to be run with admin rights on Windows
    • Improved support for ATRAC and DolbyE formats
    • Reduced size of local database dramatically
    • Increased maximum memory limit on macOS to match Windows
    • Disabled Chromecast Extension API by default
    • Improved documentation
    • Improved database referential integrity
    • Fixed bugs with the auto-updater on Windows
  • Languages:
    • Allow translation of more of the auto-updater
    • Updated translations via Crowdin
Compatibility notes:
WAusJackBauer
Re: Version 7.2.0 released
Post by WAusJackBauer » Fri Jul 27, 2018 6:33 pm
Just wanted to make sure you read this, but on my Panasonic P60S60A version 7.1.0 (and I think 7.0.1) had a fair few problems. Specifically videos that used to work on version 6.8.0 now don't and most videos don't work when I try to seek.
I've since reverted back to 6.8.0 but if providing logs can help you fix it then I may install 7.1.0 again because I love this program so much and want it to be the very best it can.
Also I'm using Windows 10 Pro 64 bit latest build and at the time was using Java8 171 not the newly released 181.
zoomcns
Post by zoomcns » Fri Jul 27, 2018 6:51 pm
After updating to 7.2.0, UMS doesn't start for me. The loading splash image just sits there indefinitely. (Win10)
boss
Post by boss » Fri Jul 27, 2018 7:12 pm
Try deleting the database folder. It will rebuild itself when UMS first starts.
This has been a common problem when moving to a new version when the database structure is changed.
Post by SubJunk » Fri Jul 27, 2018 10:20 pm
It would help us to fix it if you could post TRACE logs from 6.8.0 and 7.2.0 trying to play the same file, so we can compare exactly what is happening. Instructions at viewtopic.php?f=9&t=556
Please provide us with the logs which will probably be in c:/ProgramData/UMS/debug.log
I had hoped this problem had been fixed in 7.2.0, so either it hasn't, or this is a different one.
zoomcns
Post by zoomcns » Sat Jul 28, 2018 5:29 am
Here is the log, hope it helps.
DEBUG 2018-07-27 19:21:08.577 [main] Default logfile folder set to: C:\ProgramData\UMS
DEBUG 2018-07-27 19:21:08.697 [main] LogBack started with configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
DEBUG 2018-07-27 19:21:08.709 [main] Fri Jul 27 19:21:08 CEST 2018
DEBUG 2018-07-27 19:21:08.709 [main] Reading cred.path: "C:\ProgramData\UMS\UMS.cred" (default: "")
DEBUG 2018-07-27 19:21:09.070 [main] Writing PID: 3840
DEBUG 2018-07-27 19:21:09.198 [main]
INFO  2018-07-27 19:21:09.198 [main] Starting Universal Media Server 7.2.0
INFO  2018-07-27 19:21:09.199 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO  2018-07-27 19:21:09.200 [main] http://www.universalmediaserver.com
INFO  2018-07-27 19:21:09.200 [main] Build: 5b1c4ce22 (2018-07-27)
INFO  2018-07-27 19:21:09.200 [main] Java: Java HotSpot(TM) Client VM 1.8.0_181 (32-bit) by Oracle Corporation
INFO  2018-07-27 19:21:09.201 [main] OS: Windows 10 64-bit 10.0
INFO  2018-07-27 19:21:09.204 [main] Maximum JVM Memory: 742.4 MiB
INFO  2018-07-27 19:21:09.209 [main] Language: English (United States)
INFO  2018-07-27 19:21:09.209 [main] Encoding: UTF-8
INFO  2018-07-27 19:21:09.209 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO  2018-07-27 19:21:09.215 [main] Temporary directory: C:\Users\ZOLTN~1\AppData\Local\Temp\UMS
INFO  2018-07-27 19:21:09.217 [main] Logging configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO  2018-07-27 19:21:09.217 [main] Logfile: C:\ProgramData\UMS\debug.log
INFO  2018-07-27 19:21:09.218 [main] Profile directory: C:\ProgramData\UMS
INFO  2018-07-27 19:21:09.219 [main] Profile directory permissions: drwx
INFO  2018-07-27 19:21:09.219 [main] Profile configuration file: C:\ProgramData\UMS\UMS.conf
INFO  2018-07-27 19:21:09.220 [main] Profile configuration file permissions: -rwx
INFO  2018-07-27 19:21:09.221 [main] Profile name: Zoom-PC
DEBUG 2018-07-27 19:21:09.221 [main] Reading web_conf: "C:\ProgramData\UMS\WEB.conf" (previous: null, default: "C:\ProgramData\UMS\WEB.conf")
INFO  2018-07-27 19:21:09.221 [main] Web configuration file: C:\ProgramData\UMS\WEB.conf
INFO  2018-07-27 19:21:09.229 [main] Web configuration file permissions: -rwx
DEBUG 2018-07-27 19:21:09.247 [main] Using database URL: jdbc:h2:C:\ProgramData\UMS\database\medias
INFO  2018-07-27 19:21:09.247 [main] Using database located at: C:\ProgramData\UMS\database
DEBUG 2018-07-27 19:21:09.513 [main] Database file count: 0
DEBUG 2018-07-27 19:21:09.513 [main] Database version: 16
DEBUG 2018-07-27 19:21:09.513 [main] Starting check of database tables
INFO  2018-07-27 19:21:09.527 [main] Upgrading database table "FILES_STATUS" from version 4 to 5
ERROR 2018-07-27 19:21:09.535 [main] A serious error occurred during Universal Media Server initialization: Referential integrity constraint violation: "CONSTRAINT_ED: PUBLIC.FILES_STATUS FOREIGN KEY(ID) REFERENCES PUBLIC.FILES(ID)"; SQL statement:
ALTER TABLE FILES_STATUS ADD FOREIGN KEY(ID) REFERENCES FILES(ID) ON DELETE CASCADE [23506-196]
boss
Post by boss » Sat Jul 28, 2018 12:46 pm
@zoomcns
Delete the database folder "Using database located at: C:\ProgramData\UMS\database"
and restart UMS
erick diangilis
Post by erick diangilis » Sat Jul 28, 2018 1:01 pm
thanks for this release guys i've tested out on the ps4 media player and just like the last version is working fine, but feels more stable this time.
playback quality still pretty good on both sound and video specially on a gigabyte wired network the download and instalation process worked fine for me on windows 10 and the ums also uses very well the lastest java 10.0.2 version that i'm currently using.
thanks again for fixing the bugs and the memory usage problem keep up with good work and god bless. :D
Post by SubJunk » Sat Jul 28, 2018 1:19 pm
Thanks for this log, it looks like there is a bug in the upgrade script, I'm working on a fix now and will attach it here when it is done so you don't have to delete your database
Edit: But in the meantime you could rename the "database" folder to something else so you get to use the program. Or just delete it if you don't care about keeping the played statuses of files
Thanks Erick!
Post by SubJunk » Sat Jul 28, 2018 8:24 pm
Please let me know if this version fixes it: http://www.universalmediaserver.com/upl ... oomcns.exe
