Version 3.2.0 is released
Post by SubJunk » Sun Dec 01, 2013 4:17 pm
General:
This release lets you set your own server name, increases seeking accuracy and audio sync when using FFmpeg, and increases video compatibility for many videos including 3D (SBS and OU).
Changes since 3.1.2.1:
  • General:
    • Added font cache generation for FFmpeg on startup
    • Added the ability for users to set their own server name
    • Added example virtual folders file in the profile directory
    • The virtual folders file is now loaded from the profile directory instead of the installation directory
    • Made seeking more accurate with FFmpeg
    • When FFmpeg muxes, it always uses tsMuxeR
    • Improved compatibility with videos with unusual colorspaces
    • Improved compatibility when transcoding to H.264 via FFmpeg
    • Improved compatibility with video with HE-AAC audio
    • Improved compatibility when using tsMuxeR via FFmpeg
    • Improved compatibility with high-resolution videos such as 3D-SBS and 3D-OU
    • Fixed resume files causing a startup crash
    • Fixed some settings causing a crash
    • Fixed bug with FFmpeg subtitles
  • Languages:
    • Updated Spanish translation (thanks, AlfredoRamos!)
  • External Components:
    • Updated FFmpeg to builds from 2013-11-27, which:
      • Adds support for HEVC (H.265)
      • Improves seeking accuracy
      • Improves AV sync
      • Fixes memory leaks
      • Optimizes AC-3 decoding
      • Improves support for 60FPS videos
      • Improves AVI support
      • Silences meaningless errors
      • Improves DTS support
      • Supports seeking to non-keyframes in Matroska files
      • Improves AC-3 support
      • Fixes support for rare MP4 videos
Upgrade Notes:
For 3.0.0-b1 and newer:
No action necessary.
For all versions below 3.0.0-b1:
DeFlanko
Contact:
Re: Version 3.2.0 is released
Post by DeFlanko » Mon Dec 02, 2013 9:31 am
Excellent!
Madoka
Post by Madoka » Mon Dec 02, 2013 9:44 am
I am saddened that we will not be getting a UMS π Version.
DeFlanko
Contact:
Post by DeFlanko » Mon Dec 02, 2013 10:30 am
Madoka wrote:I am saddened that we will not get getting a UMS π Version.
hahahaha
Post by SubJunk » Mon Dec 02, 2013 10:36 am
Lol! Darn I should've done it just for that
DeFlanko
Contact:
Post by DeFlanko » Mon Dec 02, 2013 10:40 am
QUICK ROLL BACK THE CODE!!!
DeFlanko
Contact:
Post by DeFlanko » Mon Dec 02, 2013 10:41 am
or just wait till v3.14
Casper
Post by Casper » Tue Dec 03, 2013 8:51 pm
Very happy that ffmpeg subtitles are working.
domain
Post by domain » Sat Dec 07, 2013 11:11 pm
Bad version for me. ffmpeg will check the font cache every time? And ffmpeg.exe uses very high cpu! What's even worse, the UMS will be unconnectable once in a while! My render is Panasonic P46ST32C
