UMSBuilder 1.8.0 is released
General:
UMSBuilder automatically builds the latest revision of UMS for Windows and Linux.
To use it, simply extract UMSBuilder and run the build script.
Note: This will build the program from potentially untested code, so while it should usually be OK there are no guarantees.
If you want stability, download the latest official release from our front page.
Download for Windows
Download for Linux
Changes since 1.7.1:
  • General:
    • Made the Linux script keep the external components
  • External components:
    • Updated Maven to 3.2.3, which:
      • Adds more HTTPS access
    • Updated Java to 1.7.67, which:
      • Improves security
