Version 4.1.3 is released
Post by SubJunk » Fri Oct 03, 2014 11:18 am
General:
This release fixes Xbox One support, improves browsing speed, network performance, file support and more!
Changes since 4.1.2:
  • General:
    • Improved default settings for smoother playback on wired and wireless networks
    • Made FFmpeg more reliable when transcoding embedded subtitles
    • Enabled file cache by default
    • Updated logo (subtle)
    • Improved cache handling
    • Disabled FFmpeg deferring to MEncoder for subtitles by default
    • Fixed thumbnails on some Samsung TVs
    • Fixed general bugs
  • Renderers:
    • Fixed unnecessary high CPU usage on LG TVs (thanks, amalic!)
    • Fixed support for Sony Home Theatre Systems
    • Fixed support for Xbox One
    • Improved support for Samsung UE ES6575 TVs
  • Languages:
    • Updated Czech translation
    • Updated French translation (thanks, Kirvx!)
raprop
Re: Version 4.1.3 is released
Post by raprop » Sat Oct 04, 2014 12:20 am
HI!!!
Subjunk.. .still persist transcode problem with LG TV Web OS and profile LA6200.
Thx
http://ul.to/rqxyln48
Wolfgan
Post by Wolfgan » Sat Oct 04, 2014 1:38 am
Thanks for the release!
Chyaddo
Post by Chyaddo » Sat Oct 04, 2014 12:40 pm
:D :D :D :D :D
jaapie18
Post by jaapie18 » Sat Oct 04, 2014 8:46 pm
The root problem is gone with the xbox one. But now i have another problem. If i play a mkv in mencoder it does say its not supported or something. If I play via ffmpeg i don't have sound.With my ps3 i don't have those problems.
Whogie
Post by Whogie » Sun Oct 05, 2014 4:04 am
jaapie, make sure "Keep DTS tracks" is turned off in "Transcoding Settings"->"Common Transcode Settings"->"Audio Settings".
jaapie18
Post by jaapie18 » Sun Oct 05, 2014 8:41 am
Whogie wrote:jaapie, make sure "Keep DTS tracks" is turned off in "Transcoding Settings"->"Common Transcode Settings"->"Audio Settings".
So you can use DTS then on the Xbox one? I really want to use DTS.
Whogie
Post by Whogie » Sun Oct 05, 2014 11:06 am
No, I'm saying DTS is not supported so "Keep DTS tracks" needs to be off. It may come in a future update, but right now it has to be transcoded.
Storm
Post by Storm » Sun Oct 05, 2014 12:56 pm
Thanks for your work. So far it's running perfectly. I just upgraded from PMS 1.90.1 as I just learnt of UMS :lol:
sma76928
Post by sma76928 » Mon Oct 06, 2014 10:22 am
Hi:
is there any update about LG webos TV? this version stills not working with this TVs
best regads
