FAQ | Forum | Tracker | Code
Version 2.2.5 is released
Postby SubJunk » Wed Jan 16, 2013 11:54 am
General:
This release fixes video support on some renderers, adds the Server Settings folder and more!
Changes since 2.2.4:
  • General:
    • Fixed transcoding support on some renderers (thanks for testing, Raker13!)
    • Merged the Video Settings folder into the Server Settings folder
    • Fixed a bug with the cache (thanks, valib!)
    • Several code optimizations (thanks, valib!)
  • External Components:
    • Updated Java Runtime Environment automatic downloader for Windows to 7u11, which:
      • Fixes serious security holes
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X version
Re: Version 2.2.5 is released
Postby sHawTY » Wed Jan 16, 2013 12:46 pm
Does this version fix the certain "unplayable" MKV problem? :shock:
sHawTY
Postby SubJunk » Wed Jan 16, 2013 1:14 pm
It fixes some playback problems, whether it fixes your one or not, you tell us! :)
Postby squadjot » Wed Jan 16, 2013 10:47 pm
uhhh..exiting ^^ (hoping external/embedded subtitle - madness has ended)
Edit: I'm pretty sure its fixed! xD - yay!
           Windows 7 Ultimate x86 • Intel Atom GA-D525TUD @ 1.8GHZ • 2GB DDR3 RAM • LAN: Gigabit/wired +WiFi
          Renderers: Sony Bravia W5500 • WDTVLive • Playstation3 Slim • HTC One S w/BubbleUPnP
squadjot
Postby sHawTY » Thu Jan 17, 2013 3:27 pm
SubJunk wrote:It fixes some playback problems, whether it fixes your one or not, you tell us! :)
Will be testing it as soon as UMS v2.2.5 for Mac is released. :)
sHawTY
Postby stomp_442 » Fri Jan 18, 2013 2:44 pm
I am new to UMS, 2.2.4 is the first version I installed. Tried everything and still couldn't get it working. Never bothered posting because I thought I would just get the run around. Upon installing v2.2.5, my PS3 was recognized on the initial booting of UMS. Thanks for this update. Running Win 7 Premium, 32 bit.
stomp_442
Postby SubJunk » Fri Jan 18, 2013 3:45 pm
Mac version is released :)
Postby GanJi » Fri Jan 18, 2013 7:19 pm
Still no change in streaming to my Uhost2 Android - streams files fine, but transcoding files with subtitles results in "Video cannot be played." My Android.conf is untouched from the installation.
GanJi
Postby SubJunk » Fri Jan 18, 2013 9:05 pm
Hi GanJi, have you made a thread in the support section?
Postby GanJi » Fri Jan 18, 2013 11:57 pm
SubJunk wrote:Hi GanJi, have you made a thread in the support section?
I did create one here
viewtopic.php?f=5&t=515
Let me know if I need to post some logs, or move the topic in another sub-forum.
GanJi
Return to Announcements
Who is online
Users browsing this forum: No registered users and 2 guests
