This release improves MKV support, enables faster server connection on some renderers, fixes FFmpeg on Xbox and more!
Changes since 2.2.5:
- General:
- Some renderers (like Philips HTS) can connect more quickly with the server
- Improved support for Sony Bravia HX series TVs
- Improved design on OS X
- Fixed FFmpeg video transcoding on Xbox
- Fixed file permissions on Linux
- Plugins can use custom icons for files (thanks, skeptical!)
- Languages:
- Updated Korean translation (thanks, sunghyuk!)
- External Components:
- Updated MPlayer/MEncoder for Windows to SB49, which:
- Improves MP3 encoding speed
- Improves MKV support
- Improves threading
- Fixes memory leaks
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
Cameron Spiers for building the OS X version
