Version 5.3.1 is released
Post by SubJunk » Wed Nov 25, 2015 5:09 pm
General:
This release improves support for high-DPI displays, Linux, Samsung TVs, translations and more!
Changes since 5.3.0:
  • General:
    • Window state is saved when maximized
    • Improved font-scaling on high-DPI displays
    • Improved file permissions checks
    • Improved filename prettifying
    • Fixed Linux not finding FFmpeg (thanks, Oxalin!)
  • Renderers:
    • Added detection of the Edge browser
    • Fixed support for subtitles on Samsung J series TVs
  • Languages:
    • Synchronized translations with Crowdin
  • External Components:
    • Updated icu4j version to 56.1
    • Updated JGoodies Looks to 2.7.0
    • Updated JNA to 4.2.1
HT1
Re: Version 5.3.1 is released
Post by HT1 » Wed Nov 25, 2015 7:20 pm
Window size is acting weird in 5.3.1 (java8 not 7 sry/windows8.1).
ok so i set the size and position like so in ums.conf prior to launching ums:
window_geometry = x=0,y=0,width=800,height=600
screen_size = 1280x768
python.path = c:\\Python27\\python.exe
rtmpdump.path = C:\\PROGRA~2\\UNIVER~1\\win32\\rtmpdump.exe
youtube-dl.lib.path = C:\\PROGRA~2\\UNIVER~1\\win32\\YOUTUB~1
engines = ffmpegvideo,mencoder,tsmuxer,ffmpegaudio,tsmuxeraudio,ffmpegwebvideo,vlcwebvideo,vlcvideo,mencoderwebvideo,vlcaudio,ffmpegdvrmsremux,rawthumbs
window_extended_state = 0
launched ums, the window size was as i set it. then maximized it and quit. it changed to:
window_geometry = x=0,y=0,width=1000,height=750
i don't know why but height and width changed all by themselves.
Win 10 64bits java 8
Qnap TS-212 2x3TB WD Red
Sony Bravia MN (my conf)
valib
Post by valib » Thu Nov 26, 2015 2:44 am
Thanks for the report. I will fix it.
phrozenstare
Post by phrozenstare » Thu Nov 26, 2015 9:20 am
has anyone else been having issues with the auto update lately? this is the second time it told me there is an update but it couldn't install it because the program doesn't have admin privileges. i am on windows 10 and am the administrator. i also tried making the program always run in admin mode but then that breaks the program from starting up with windows
HT1
Post by HT1 » Fri Nov 27, 2015 11:14 am
phrozenstare wrote:has anyone else been having issues with the auto update lately? this is the second time it told me there is an update but it couldn't install it because the program doesn't have admin privileges. i am on windows 10 and am the administrator. i also tried making the program always run in admin mode but then that breaks the program from starting up with windows
i saw it too on win8.1 can't say for win7 as i had updated it manually.
theChantos
Post by theChantos » Sun Nov 29, 2015 10:46 am
Nice job!
Here an advice:
I like to put all my media in Windows Server OS, that works pretty well for me beacuse my server has more resources that any PC (Xeon processors, 16+ RAM, SAS Hard Drives, etc) which is good to render 1080p movies.
Having said so, installing UMS as a service (which is the best runnning option for a Windows Server) takes a bit more than a few steps to get done. I.E. WS requires to install services with an LOCAL_SERVICE account in order to get the Processor IO priority beneffits, also, the service cannot be controlled from the UMS UI beacuse it is not recognized at all and you can end with two instances working at the same time.
I think it requires a little more effort to correct the UMS installer to be given as a service instead as an application. Windows Server is the default for those who use UMS in server arquitectures.
It worth it.
Thanks!, Eduardo!.
ExSport
Post by ExSport » Thu Dec 03, 2015 3:48 am
Multimedia Class Scheduler Service:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
