Version 2.5.1 is released
Post by SubJunk » Fri Mar 15, 2013 11:36 am
General:
This release makes libraries and files load faster, improves subtitle support, adds 2 new renderers and more!
Note: This release requires Java 7 to be installed. It will not run on Java 6.
Changes since 2.5.0:
  • General:
    • Improved subtitle support on non-PS3 renderers
    • Made library/file loading faster
    • Fixed 24-bit flac support with tsMuxeR
    • Stopped using 2 database locations for media caching on Windows
    • Allow library scanning to be stopped
    • Library scanning interface improvements
  • Renderers:
    • Added support for Sony Home Theatre systems
    • Added support for Onkyo TX-NR717
    • Improved Samsung AllShare compatibility
Upgrade Notes:
For versions prior to 1.5.0:
For all versions:
kuroukage
Re: Version 2.5.1 is released
Post by kuroukage » Fri Mar 15, 2013 1:45 pm
Thanks for the update, SubJunk.
黒影
starterz
Post by starterz » Fri Mar 15, 2013 7:26 pm
Thank you for the update, downloading now. Will test it later tonight.
Stay well.
sHawTY
Post by sHawTY » Sat Mar 16, 2013 4:28 am
Here's hoping v2.5.1 will be available for Mac OS X. :D
