Sony KDL-EX725 doesn't see UMS
eva01
Post by eva01 »
Hi every one,
I've been running PMS perfectly. Now when I run UMS, my Sony KDL-EX725 doesn't see it and UMS doesn't see the Sony. I've tried from a different computer (both Win7 x64) and nothing.
When I close down UMS and run PMS SB71, everything is normal. I've check the configuration in UMS and it matches with my old PMS settings.
Any suggestions?
thanks
Secate
Re: Sony KDL-EX725 doesn't see UMS
Post by Secate »
Seems we are having the same issue with Xbox 360's:
viewtopic.php?f=9&t=6&p=26#p26
This bug is my top priority and I expect to release a fix later today
eva01
Post by eva01 »
Yes, similar, but in my case none of the 2 is seen with UMS.
I had to download and reinstall build 71.
Please let me know if it still happens with this one.
eva01
Post by eva01 »
I uninstall UMS 1.0, install the test file. Only works one time after the installation, then no. PMS 71 still working.
Thanks for testing :) What about this one?
eva01
Post by eva01 »
Without uninstall 1.52 SB71, install the test file in other directory and it works. Took all the settings of the 1.52 SB71 version and plugins
Hmm OK, this is a weird bug so it may take a bit of testing.
Please try this one :)
eva01
Post by eva01 »
He started working fine after installation. After installing the plugin PMSENCODER stopped working. Strange, because in PMS 1.52 SB71 everything works fine.
