Bad audio sync problems in the last week
Hi all,
Firstly, forgive me but I'm a bit of a n00b at these things. I've been using servers of some description for years but generally install and forget them. I've been using UMS since last october when I moved to Win10.
Everything has been fine. Great server.
Until last week or so. Everything I watch, the audio goes out of sync immediately and at it's worst can easily be 2 seconds out. All file types seem to be affected but known tests have been mkv, mp4, avi.I'm using Version 7.0.0-b2 and stream across a lan to my PS4.
If anyone has any ideas?
Thank you.
Thank you.
Re: Bad audio sync problems in the last week
After having installed UMS 6.7.1 version, that have the latest updates and have a better log verbose, please, attach your full trace log as explained in red above your post. Thank you for your understanding.
