IPTV encoding issue question
asmol
Post by asmol »
Hello!
First, I want to thank you for the new version of the server - everything works well and is great in Windows, at least. There is a small problem with the IPTV playlists. Or rather, with their encoding. Please look at the attachment (https://www.dropbox.com/s/d29x709kssnur ... v.m3u?dl=0). This playlist is in UTF-8 encodings. Tell me in which encoding I need to re-encode it, so that it is normally displayed on Android? This is Russian encoding. And can I use Notepad ++ for this?
MartianMARTIN
Re: IPTV encoding issue question
Post by MartianMARTIN »
You should try to re-encode your IPTV links!! That playlist if not working because of some problem in the playlist. Just try to re-encode, the playlist in some other format and this will surely, give you a working iptv links playlist
