Subtitle color always white for external subtitles * SOLVED *
Pan Borowik
Post by Pan Borowik » Thu Jun 29, 2017 7:17 pm
Hello!
I'm using the latest UMS version with Panasonic ST60 series TV, and it works great apart from the subtitle color for when I use external .srt subtitles.
I have selected orange color in options for the subtitles, and when I play a .mkv file that has the subtitles already inside, it's working just fine.
However, when I play a video with external subtitles in .srt format, the color is always white.
Is there another setting somewhere that I should change?
It's a clean install with default config, the only changes I've made are the color selection and adding the source folder with movies to the list.
Madoka
Re: Subtitle color always white for external subtitles
Post by Madoka » Fri Jun 30, 2017 4:32 am
Check "Use font settings..." in the FFmpeg tab.
Pan Borowik
Post by Pan Borowik » Sat Jul 01, 2017 10:32 pm
Holy cow, that fixed it. Thanks a bunch!
