don´t show "web" and "#--MOVIE INFO--#"
Hi
can i disable "web" and "#--MOVIE INFO--# - i don´t want do see it
Thank´s
Thank´s
Re: don´t show "web" and "#--MOVIE INFO--#"
Start by removing you plugins.
Thanks - "Movie info" is away but i doesn´t find something about "web"
i found it - c:\programData\ums\web.conf - i changed it to web.conf_old
Great. I wasn't sure if it was "that" web folder or one created by a plugin.
@hannesm "Web" folder is only displayed if you have selected "Enable external network" in the "General Configuration" tab from the GUI.
@Sami32 @hannesm You should not disable "external network" only to hide the web folder. This will also disable all other use of internet, like looking up movie information, subtitles, album art and more. The correct way to disable it is with web.conf.
