UMS won't start on W10 Fall Creators
Hello folks, I've a problem with UMS after install the program try to start but he won't start, so i just go into program's folder and try to start the java version and nothing happen, same thing with the bat versione, anyone can help me :S before the format everything work fine but after the format i've this problem.
P.S. The java version isntalled on my pc is the 8 Version update 151 build 1.8.0_151-b12
Re: UMS won't start on W10 Fall Creators
Disable your firewall(s) on your computer and everything should be fine. After that you should configure your firewall correctly for UMS, depending of your OS and firewall used.
If still not start, then post your debug.log file found into your profile folder, the place will depend on your OS. If you don't know where to find it, you can run a search for it, or search advises into the forum threads related to your OS.
