picture problem
Vitalii
picture problem
Post by Vitalii »
Hi all.
I have had problem with streaming pictures.
When i streaming pictures they do not show in full TV screen resolution. Can you help me and give some advise.
Thanks.
Re: picture problem
Does the pictures have the same aspect ratio as the TV? You can't expect the pictures to be stretched - or do you simply mean that they aren't properly resized to fill either the height or the width?
Vitalii
Re: picture problem
Post by Vitalii »
Picture don`t resize
Re: picture problem
That's supposed to be the responsibility of your renderer, not UMS. You give very little information, please post debug files as explained above so we can see if there's anything abnormal going on.
Vitalii
Re: picture problem
Post by Vitalii »
This archive where you can find all log files
https://drive.google.com/open?id=1hHOAf ... SvdXwL1BuT
Re: picture problem
When you say "pictures", do you actually mean pictures/images, or are you referring to video?
Sami32
Re: picture problem
Post by Sami32 »
Hi Vitalii,
I guess that you have that issue only for a specific renderer ? which one ?
If you could post a photo of your TV with an example of picture that give you issue, that should help us to understand better what exactly you are talking about.
Thank you for your understanding.
Vitalii
Re: picture problem
Post by Vitalii »
Nadahar wrote: Sat Nov 25, 2017 6:42 am When you say "pictures", do you actually mean pictures/images, or are you referring to video?
Yes, i mean image/picture
Vitalii
Re: picture problem
Post by Vitalii »
Sami32 wrote: Sat Nov 25, 2017 9:31 am Hi Vitalii,
all image gave same result. all of them don`t open on full screen
Link for photo :
https://drive.google.com/open?id=1DLlZF ... uh7uqw_lgl
Sami32
Re: picture problem
Post by Sami32 »
@Vitalii
Sami32 wrote: Sat Nov 25, 2017 9:31 am I guess that you have that issue only for a specific renderer ? which one ?
Thanks, that helped to see that you are having pictures size display issue with your Samsung LE40D550 renderer.
1) Do XBMC, VLC, WMP...display them correctly ?
2) What is the original resolution of BUS.jpg ?
As i don't see that you've reproduced your issue into your log...we miss all the informations, AFAIU.
EDIT: Could you try to disable all the renderers except the Samsung CD, from the GUI General Configuration tab, and add this line into your UMS.conf in your profile repository ?
chromecast_extension = false
Just for eliminate possible interferrence between renderers.
