picture problem
Re: picture problem
1) vlc show all images normalySami32 wrote: ↑Tue Nov 28, 2017 2:29 am @VitaliiThanks, that helped to see that you are having pictures size display issue with your Samsung LE40D550 renderer.
1) Do XBMC, VLC, WMP...display them correctly ?
2) What is the original resolution of BUS.jpg ?
As i don't see that you've reproduced your issue into your log...we miss all the informations, AFAIU.
EDIT: Could you try to disable all the renderers except the Samsung CD, from the GUI General Configuration tab, and add this line into your UMS.conf in your profile repository ?Just for eliminate possible interferrence between renderers.Code: Select all
chromecast_extension = false
2) image size is 1024*731 ( i have resized in both ways and it did not help)
3)i have added
Re: picture problem
@Vitalii
Ok, thanks. So you've only that issue with your Samsung renderer.
So, if i understood you correctly, when you resize or use original pictures with a resolution of 1920x1080 or more, the picture display is still not fully using your Samsung renderer full screen, is that correct ?
Then restart UMS and test the pictures display on your Samsung a new time.
After that, consider follow the steps explained above your first post, and post a full TRACE log AFTER having reproduced your issue, or we cannot see what happen neither help you...
From the UMS' GUI, go in the "General Configuration" tab, click on "Select renderers" then deselect them all, and then only select +Samsung --> C/D series.EDIT: Could you try to disable all the renderers except the Samsung CD, from the GUI General Configuration tab, and add this line into your UMS.conf in your profile repository ?
Re: picture problem
I did what you told, and this didn`t help.Sami32 wrote: ↑Wed Nov 29, 2017 6:55 am @Vitalii
Link for Logs:
https://drive.google.com/open?id=1qi6xB ... jGXDUe5Vl4
Re: picture problem
Your log files are useless to us as you didn't follow the procedure described. You have to restart in "Trace" mode before reproducing the problem (that is, viewing some of those pictures) when creating the log. Also, please let us know the exact filename of at least one image with this problem that has a large enough resolution that it should fill your TV screen.
Re: picture problem
I did it and send logs last time. Now i made it again.
I deselected all renders, and after that selected only Samsung C/D render. Restart UMS. And result is the same.
Link on log : https://drive.google.com/open?id=1Bsnr1 ... lqji7CtpPb
Re: picture problem
@Vitali You logs aren't TRACE logs. You have to follow the instructions and select "Restart in TRACE mode" before capturing the log.
Re: picture problem
OOOPS!!!! Sorry.
i have restarted in TRACE mode and get all logs
link : https://drive.google.com/open?id=1Tigje ... VSJthj5fch
Re: picture problem
You made a mistake when you add '[code']chromecast_extension = false'[/code'] to UMS.conf but you have to add only "chromecast_extension = false" without quotes. Better remove the added line and find in the UMS.conf theVitalii wrote: ↑Tue Dec 05, 2017 7:40 pmOOOPS!!!! Sorry.
false
Re: picture problem
i founded and changed chromecast_extension to false and restart server, and it didn't helpvalib wrote: ↑Wed Dec 06, 2017 1:28 amYou made a mistake when you add '[code']chromecast_extension = false'[/code'] to UMS.conf but you have to add only "chromecast_extension = false" without quotes. Better remove the added line and find in the UMS.conf theVitalii wrote: ↑Tue Dec 05, 2017 7:40 pmOOOPS!!!! Sorry.
link : https://drive.google.com/open?id=1Tigje ... VSJthj5fchat the line 240 and addCode: Select all
Next problem is that your TV was not recognized when you made a log. Have you ever tried to browse folders and show pictures?Code: Select all
false
every time i browse folder and select pictures.
Re: picture problem
What do you mean : "Have you ever tried to browse folders and show pictures?"?
