Samsung qe65q7f - playing UHD content
limbodfl
Post by limbodfl » Fri Dec 01, 2017 5:47 pm
My new Samsung qe65q7f doesn't play uhd content.
I tried Inferno :
Format : Matroska
Format version : Version 4 / Version 2
File size : 38.4 GiB
Duration : 2 h 1 min
Overall bit rate : 45.2 Mb/s
Subs : NL (Instelbaar, SRT)
_________________________________________________
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 43.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.220
Stream size : 37.1 GiB (97%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : SMPTE ST 2084
Matrix coefficients : BT.2020 non-constant
