Transcode folder olnly?
I have just found UMS for my new TV and it works great!
This is a very nice software, thank you for sharing it!
Now a question: I have enabled the optional "#-- TRANSCODE --#" folder: I really like it, since it allows me to pick up my very own transcode settings (most of the times "no transcode" will work).
Since I am no longer accessing the files directly anymore, Is there an option to make the "#-- TRANSCODE --#" folder the only folder?
Re: Transcode folder olnly?
No, but if you configure UMS correctly you can make the choice outside the TRANSCODE folder be the correct choice 99% of the time.
