What do the various whitelist options mean?
I am brand new to UMS, so I'm still struggling to understand bits and pieces.
On the security and privacy page, the whitelist section lists a number of properties.
Most of them seem obvious, but some are meaningless to me. A search has revealed nothing to me.
I've listed the options below with what I believe that each one means. Where can I find further information, or can you correct me where I'm wrong, please?
Thank you
- ini: (no idea)
- folders: A comma-separated list of allowed folders
- vfolders: (no idea)
- plugins: A list of allowed plugins
- web: (no idea)
- recent: Whether or not to hide the "recents" list; true means hide, false means show.
- new_media: Whether or not to show a "New media" section
- hide_set: Whether or not to hide settings
Thank you
Re: What do the various whitelist options mean?
I'm no expert in these settings myself, the developer that made this isn't very active anymore so I doubt he will answer, but I guess he's the only one that knows anything more than what is in the documentation.
To fill in the little information I can add to what you've already figured out:
- ini: I have no idea either, but where did you find this? It's not listed on the Wiki.
- vfolders: A comma-separated list of allowed virtual folders. You can configure "virtual" folders in another configuration file that isn't a real folder, but can act as one with the content (files or folders) you specify in its configuration.
- web: I don't know, but I would guess it would be a comma-separated list of allowed URLs
Regarding the "ini" it is a part of formatting and there were some wrong formats I fixed after I read this topic. Now it is not listed.
Thank you. I don't suppose that you know what the "web" value means?
Thanks. Following links and searching some more, I found the explanation in UMS.conf. It's not at all clear whether you use a single line or multiple lines for multiple virtual folders, but that can be figured out through trial-and-error.
Excellent, thank you.
