Subtitles are not showing
Re: Subtitles are not showing
Yes, when the subtitles aren't marked as "forced" UMS can't guess it - so you'd either have to select the correct subtitles track manually from within the TRANSCODE folder or remux it with the correct marking.
Nope, still no luck. I've attached a new debug and mediainfo text for the updated file. Maybe it's because the Audio is technically English? And there's no way for UMS to determine when there is Spanish audio in certain scenes? Ugh. Guess I have to find a way to burn in subtitles, but I don't want to have to re-encode.
- S03E03 - I.F.T.720p.BluRay.X264 (1).mkv.txt
- (7.5 KiB) Downloaded 487 times
- (601.26 KiB) Downloaded 489 times
No, this should have worked. It seems that the problem now is:
Since you got the "normal" subtitles when you turned on English subtitles, UMS must have recognized them in the original file. The question is if your remuxing has altered their metadata in any way. Does your remuxed file display subtitles in VLC etc?
TRACE 2018-07-27 12:10:24.373 [Library Scanner] net.pms.encoders.Player Disabled the subtitles: id: 0, type: UNKNOWN, lang: off
Yes it does, VLC plays the file no problem. I even tried to remux the file and changed the language type to multiple, but then UMS would not even play the file.
After upgrading from 9.2.0 to 9.3.0, 9.4.0, 9.4.1, 9.4.2, etc. MOST subtitle files .SRT have stopped working on my Sony Bravia TV. They still work on the Roku player.
I know SOMETHING changed with subtitles for 9.3.0, but what can I do to change my subtitle files to get it to start working again? Is it the encoding (Windows/ANSI vs. Unix, or the Encoding (UTF-8)??)
VLC plays the subtitles on ALL my videos.
Subtitle Language Priority: eng,jpn,ger,und
Automatically load .srt subtitles with same filename: checked on
Force external subtitles: checked on
Example video that does not show subtitles under newer versions is:
"D:\0pending\Series\Lost World, The (1999-2002)\Season 1\The Lost World-s01e01-The Journey Begins.srt"
Debug file for 9.4.2...(subtitle does not work on TV)
https://1drv.ms/u/s!AhMwffFZTNE3grgsc31 ... A?e=spEXc3
Debug file for 9.2.0 (subtitle works on TV)
https://1drv.ms/u/s!AhMwffFZTNE3grgtHse ... A?e=gheEp6
I see this in the debug log:
TRACE 2020-04-24 18:57:40.629 [HTTPv2 Request Worker 5] net.pms.network.RequestV2 Did not send subtitle headers because the external subtitles format isn't supported by the renderer
The external subtitle format should be the same for ALL my .SRT files. The renderer has not problem displaying subtitles from other videos.
I had a quick look at the Sony-BraviaHX.conf and there is no mention of any supported external subtitles
try adding to the config
I don't know exactly what has changed but there has been some bug fixes to the subs, it just happened to break the way it was working for you.
SupportedExternalSubtitlesFormats = SUBRIP
I tried adding the following line to Sony-BraviaHX.conf
But since it is not in either the old version (that works), nor in the new version (that doesn't work), it had no effect.
There must have been a coding change.
Here's an updated debug log file.
https://1drv.ms/u/s!AhMwffFZTNE3grguz0v ... g?e=W3s26L
They broke subtitles for most users in one of the 9.x versions. I'd stick to an earlier version, at least until they address this. As per now, they seem to address it only on a per-renderer basis, so somebody has to complain for each and every renderer and this must then be "investigated" before the renderer configuration is updated.
The real reason for the problems is that they changed the rules for how subtitles support is specified in renderer configurations, but didn't bother to actually update the renderer configurations accordingly. I haven't studied these changes in enough detail to be able to tell you how you must modify your current configuration to make it work, as I think these changes should never have been merged without this already being addressed.
How do we complain to someone, and who do we complain, to get the renderer for Sony-BraviaHX TVs fixed?
You can complain all you want here, but I wouldn't bet on it having the desired effect. You best chance is to make somebody want to help you.
