Streaming pauses after a few minutes
I have a budget TV running android OS.
I have attached a log file as required. Streaming will pause after 4 - 5 minutes on multiple files. The error log shows:
11:49:06 INFO Buffer read ArrayIndexOutOfBoundsException error:
11:49:06 INFO readCount: "207118336"
11:49:06 INFO maxMemorySize: "209715200"
Any reason what might be causing this? I have updated USM, JAVA and restarting the PC also doesn't help. Is this a transcode buffer memory issue?
Edit: I tried updating to Java 64bit as well just now however the issue remains
- debug.log
- (165.75 KiB) Downloaded 378 times
Re: Streaming pauses after a few minutes
Can no one help?
There are a lot of "connection forcibly closed by the remote host" errors in the logs. I can't compile for Windows right now but I will make you a test build soon to see if it helps
Thanks. I have installed and will test and report back over the next couple of days
