External ass subtitle files
DiksonH
Post by DiksonH »
I am using kodi on a Sony TV which supports external ass file when reading from a usb drive.
However when I play the same video from UMS server, Kodi cannot read the external ass file. Is external ass file supported in UMS?
Internal ass subtitle works fine though.
Re: External ass subtitle files
We do support it. In the Kodi config I can see we are using the SubtitleHttpHeader setting which is a specific way to send subtitles, but maybe that only works for certain filetypes on Kodi. Can you please follow the Problem Reporting Guidelines above so I can look at the logs?
DiksonH
Post by DiksonH »
I was playing "test ass.mkv" and the subtitle does not show.
Debug log attached.
(47.88 KiB) Downloaded 338 times
Ah I see, so it seems the play request is coming from the Sony TV and not Kodi. Not sure if that is our fault or the TV's:
Started playing test ass.mkv on your KD-43X7500F
and since the TV only supports SRT subtitles, it doesn't try to stream the ASS subtitles.
I have created an issue on our tracker for this https://github.com/UniversalMediaServer ... ssues/1639
DiksonH
Post by DiksonH »
SubJunk wrote: Tue Oct 23, 2018 8:33 pm Ah I see, so it seems the play request is coming from the Sony TV and not Kodi. Not sure if that is our fault or the TV's:
It's actually another bug. If kodi is active while I turn off the TV (standby mode) the renderer becomes KD-43X7500 (using xbmc or chromecast ultra.conf). I turn off all transcoding engines as a work around.
I tried restarting kodi, and even when the renderer is kodi, external ass problem still exists.
Another weird thing is when I embed the ass subtitle into test ass.mkv, the subtitle shows correctly as an internal one.
Debug log is attached.
(50.22 KiB) Downloaded 302 times
