new ums 3.0 final doesn't detect my ps3
the new ums 3.0 final don't detect my ps3.
I turned the option to ignore it as a renderer off, but that didn't help.
When i re-installed ums 2.6.5 everything worked fine , even after a clean install.
When i the re-install version 3.0, the problem is back
Re: new ums 3.0 final don't detect my ps3
I have the same problem on a Dvico Tvix N1.
I have what I think to be a similiar problem...
My smart tv streams fine but ums has to be manually restarted one to several times to see devices and when I go into ums through the ps3 (in other room) it can't see the media files...no its not just cuz im using a music search for video, etc.
did you install ums with the check box "clean install"?
like @Subjunk mentioned in another post its best to do clean installs as it replaces items in the programdata folder
Sent from my SGH-T999 Using ForumTouch for Android
Yes i have checked the clean install
- Optimus_prime
Please submit a Log set on trace, making sure you restart the server (via the restart server button) after.
Same problem here. Sometimes it detects the PS3 after 20-30 minutes, but does not list any files.
11-04 19:06:26 Starting Universal Media Server 3.0.0
11-04 19:06:26 Based on PS3 Media Server by shagrath, copyright 2008-2013
11-04 19:06:26 http://www.universalmediaserver.com
11-04 19:06:26
11-04 19:06:26 Build: 8ae6b1f86 (2013-11-01)
11-04 19:06:26 Java: Java HotSpot(TM) Client VM 1.7.0_45 32-bit by Oracle Corporation
11-04 19:06:26 OS: Windows 7 64-bit 6.1
11-04 19:06:26 Encoding: UTF-8
11-04 19:06:26 Memory: 742 MB
11-04 19:06:26 Language: de
11-04 19:06:26
11-04 19:06:26 Working directory: D:\Programme\Media\Universal Media Server
11-04 19:06:26 Temp directory: C:\Users\Heiko\AppData\Local\Temp\universalmediaserver
11-04 19:06:26 Logging config file: D:\Programme\Media\Universal Media Server\logback.xml
11-04 19:06:26 debug.log: C:\ProgramData\UMS\debug.log
11-04 19:06:26
11-04 19:06:26 Profile directory: C:\ProgramData\UMS
11-04 19:06:26 Profile directory permissions: rw
11-04 19:06:26 Profile path: C:\ProgramData\UMS\UMS.conf
11-04 19:06:26 Profile permissions: rw
11-04 19:06:26 Profile name: Heiko-Desktop
11-04 19:06:26
11-04 19:06:26 Web conf path: C:\ProgramData\UMS\WEB.conf
11-04 19:06:26 Web conf permissions: rw
11-04 19:06:26
11-04 19:06:26 Checking shared folder: J:\
11-04 19:06:26 Loading MediaInfo library
11-04 19:06:26 Loaded MediaInfoLib - v0.7.64
11-04 19:06:26 Loading renderer configurations from D:\Programme\Media\Universal Media Server\renderers
11-04 19:06:26 Loaded configuration for renderer: PlayStation 3
11-04 19:06:26 Please wait while we check the MPlayer font cache, this can take a minute or so.
11-04 19:06:27 Finished checking the MPlayer font cache.
11-04 19:06:27 VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
11-04 19:06:27 Found VLC version 2.1.0 at: D:\Programme\Media\VLC\vlc.exe
11-04 19:06:27 Searching for plugins in D:\Programme\Media\Universal Media Server\plugins
11-04 19:06:31 Found plugin: com.chocolatey.pmsencoder.Plugin
11-04 19:06:31 Found plugin: com.sharkhunter.channel.CH_plugin
11-04 19:06:31 Exception in thread "main" java.lang.VerifyError: class com.chocolatey.pmsencoder.PMSEncoder overrides final method launchTranscode.(Ljava/lang/String;Lnet/pms/dlna/DLNAResource;Lnet/pms/dlna/DLNAMediaInfo;Lnet/pms/io/OutputParams;)Lnet/pms/io/ProcessWrapper;
11-04 19:06:31 at java.lang.ClassLoader.defineClass1(Native Method)
11-04 19:06:31 at java.lang.ClassLoader.defineClass(Unknown Source)
11-04 19:06:31 at java.security.SecureClassLoader.defineClass(Unknown Source)
11-04 19:06:31 at java.net.URLClassLoader.defineClass(Unknown Source)
11-04 19:06:31 at java.net.URLClassLoader.access$100(Unknown Source)
11-04 19:06:31 at java.net.URLClassLoader$1.run(Unknown Source)
11-04 19:06:31 at java.security.AccessController.doPrivileged(Native Method)
11-04 19:06:31 at java.net.URLClassLoader.findClass(Unknown Source)
11-04 19:06:31 at java.lang.ClassLoader.loadClass(Unknown Source)
11-04 19:06:31 at java.lang.Class.getDeclaredConstructors0(Native Method)
11-04 19:06:31 at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
11-04 19:06:31 at java.lang.Class.getConstructor0(Unknown Source)
11-04 19:06:31 at java.lang.Class.newInstance(Unknown Source)
11-04 19:06:31 at net.pms.external.ExternalFactory.instantiateEarlyListeners(ExternalFactory.java:418)
11-04 19:06:31 at net.pms.external.ExternalFactory.lookup(ExternalFactory.java:398)
11-04 19:06:31 at net.pms.PMS.init(PMS.java:675)
11-04 19:06:31 at net.pms.PMS.createInstance(PMS.java:1061)
11-04 19:06:31 at net.pms.PMS.main(PMS.java:1157)
Disable Channels Plugin and try again.11-04 19:06:31 Found plugin: com.sharkhunter.channel.CH_plugin
Universal Media Server Wiki!
It detects my other PC 192.168.1.62 after several minutes and partially another element UPNP (ISP box) 192.168.1.23 (it is not displayed on the interface connected to the media), but nothing on my Dvico 192.168.1.3
And sometimes it does not detect the PC 192.168.1.62.
No plugins enabled.
I said that everything works to perfection with version 2.6.4
EDIT: I truncate the log repetitions of "NOTIFY" to post.
No plugins enabled.
INFO 2013-11-05 16:39:16.814 [AWT-EventQueue-0] Changed debug level to TRACE
DEBUG 2013-11-05 16:39:18.650 [background-task-0] singleton task restart started
DEBUG 2013-11-05 16:39:18.650 [background-task-0-restart(0)] task started
TRACE 2013-11-05 16:39:18.650 [background-task-0-restart(0)] Waiting 1 second...
INFO 2013-11-05 16:39:18.650 [background-task-0-restart(0)] Sending BYEBYE...
TRACE 2013-11-05 16:39:18.833 [background-task-0-restart(0)] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:39:18.834 [background-task-0-restart(0)] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:39:18.834 [background-task-0-restart(0)] Socket Timeout: 0
TRACE 2013-11-05 16:39:18.834 [background-task-0-restart(0)] Socket TTL: 32
TRACE 2013-11-05 16:39:18.834 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:64203]
INFO 2013-11-05 16:39:18.834 [background-task-0-restart(0)] Stopping server on host 192.168.1.89 and port 5001...
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checkNetworkInterface(parent = null, child interfaces = java.net.NetworkInterface$1@2dfb9cf1)
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checking lo, display name: Software Loopback Interface 1
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] available addresses for lo is: [/127.0.0.1]
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checkNetworkInterface(parent = lo, child interfaces = java.net.NetworkInterface$1subIFs@61fca9cc)
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checkNetworkInterface(parent = lo) finished
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] sub address for lo is []
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checking /127.0.0.1 on lo
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] has /127.0.0.1, which is skipped, because loopback=true, ipv6=false
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] found lo, without valid address
TRACE 2013-11-05 16:39:20.024 [background-task-0-restart(0)] checking net0, display name: WAN Miniport (SSTP)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] available addresses for net0 is: []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net0, child interfaces = java.net.NetworkInterface$1subIFs@12efc256)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net0) finished
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] sub address for net0 is []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] found net0, without valid address
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checking net1, display name: WAN Miniport (L2TP)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] available addresses for net1 is: []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net1, child interfaces = java.net.NetworkInterface$1subIFs@3abfa5d0)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net1) finished
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] sub address for net1 is []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] found net1, without valid address
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checking net2, display name: WAN Miniport (PPTP)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] available addresses for net2 is: []
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net2, child interfaces = java.net.NetworkInterface$1subIFs@7c1f18d1)
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] checkNetworkInterface(parent = net2) finished
TRACE 2013-11-05 16:39:20.025 [background-task-0-restart(0)] sub address for net2 is []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] found net2, without valid address
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checking ppp0, display name: WAN Miniport (PPPOE)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] available addresses for ppp0 is: []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = ppp0, child interfaces = java.net.NetworkInterface$1subIFs@5d968100)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = ppp0) finished
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] sub address for ppp0 is []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] found ppp0, without valid address
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checking eth0, display name: WAN Miniport (IPv6)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] available addresses for eth0 is: []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = eth0, child interfaces = java.net.NetworkInterface$1subIFs@43ef5700)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = eth0) finished
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] sub address for eth0 is []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] found eth0, without valid address
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checking eth1, display name: WAN Miniport (Network Monitor)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] available addresses for eth1 is: []
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = eth1, child interfaces = java.net.NetworkInterface$1subIFs@1638e3d8)
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] checkNetworkInterface(parent = eth1) finished
TRACE 2013-11-05 16:39:20.026 [background-task-0-restart(0)] sub address for eth1 is []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] found eth1, without valid address
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checking eth2, display name: WAN Miniport (IP)
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] available addresses for eth2 is: []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = eth2, child interfaces = java.net.NetworkInterface$1subIFs@70f6854d)
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = eth2) finished
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] sub address for eth2 is []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] found eth2, without valid address
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checking ppp1, display name: RAS Async Adapter
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] available addresses for ppp1 is: []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = ppp1, child interfaces = java.net.NetworkInterface$1subIFs@48a9bc2b)
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = ppp1) finished
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] sub address for ppp1 is []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] found ppp1, without valid address
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checking net3, display name: WAN Miniport (IKEv2)
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] available addresses for net3 is: []
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = net3, child interfaces = java.net.NetworkInterface$1subIFs@7f80d051)
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] checkNetworkInterface(parent = net3) finished
TRACE 2013-11-05 16:39:20.027 [background-task-0-restart(0)] sub address for net3 is []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] found net3, without valid address
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checking eth3, display name: Realtek PCIe GBE Family Controller
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] available addresses for eth3 is: [/192.168.1.89]
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] non loopback/ipv4 addresses: [/192.168.1.89]
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checkNetworkInterface(parent = eth3, child interfaces = java.net.NetworkInterface$1subIFs@61ecb73c)
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checkNetworkInterface(parent = eth3) finished
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] sub address for eth3 is []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checking /192.168.1.89 on eth3
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] found eth3 -> 192.168.1.89
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checking net4, display name: Carte Microsoft ISATAP
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] available addresses for net4 is: []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checkNetworkInterface(parent = net4, child interfaces = java.net.NetworkInterface$1subIFs@7bf1f65d)
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checkNetworkInterface(parent = net4) finished
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] sub address for net4 is []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] found net4, without valid address
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checking net5, display name: Teredo Tunneling Pseudo-Interface
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] available addresses for net5 is: []
TRACE 2013-11-05 16:39:20.028 [background-task-0-restart(0)] checkNetworkInterface(parent = net5, child interfaces = java.net.NetworkInterface$1subIFs@4a65933d)
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checkNetworkInterface(parent = net5) finished
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] sub address for net5 is []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] found net5, without valid address
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] child network interface (eth4,TAP-Win32 Adapter V9) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checking net6, display name: Carte Microsoft ISATAP #2
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] available addresses for net6 is: []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checkNetworkInterface(parent = net6, child interfaces = java.net.NetworkInterface$1subIFs@52a5aff3)
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checkNetworkInterface(parent = net6) finished
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] sub address for net6 is []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] found net6, without valid address
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checking net7, display name: Carte Microsoft ISATAP #3
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] available addresses for net7 is: []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checkNetworkInterface(parent = net7, child interfaces = java.net.NetworkInterface$1subIFs@7bc2a4e8)
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checkNetworkInterface(parent = net7) finished
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] sub address for net7 is []
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] found net7, without valid address
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] checking net8, display name: Carte USB D-Link DWA-140 RangeBooster N
TRACE 2013-11-05 16:39:20.029 [background-task-0-restart(0)] available addresses for net8 is: []
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checkNetworkInterface(parent = net8, child interfaces = java.net.NetworkInterface$1subIFs@27d8bad2)
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checkNetworkInterface(parent = net8) finished
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] sub address for net8 is []
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] found net8, without valid address
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checking net9, display name: Carte Microsoft ISATAP #4
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] available addresses for net9 is: []
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checkNetworkInterface(parent = net9, child interfaces = java.net.NetworkInterface$1subIFs@5d1456e)
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checkNetworkInterface(parent = net9) finished
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] sub address for net9 is []
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] found net9, without valid address
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] child network interface (eth5,TAP-Win32 Adapter V9) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] checking net10, display name: Carte Microsoft ISATAP #5
TRACE 2013-11-05 16:39:20.030 [background-task-0-restart(0)] available addresses for net10 is: []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net10, child interfaces = java.net.NetworkInterface$1subIFs@6e253bbd)
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net10) finished
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] sub address for net10 is []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] found net10, without valid address
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checking net11, display name: NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] available addresses for net11 is: []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net11, child interfaces = java.net.NetworkInterface$1subIFs@4e752dc9)
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net11) finished
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] sub address for net11 is []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] found net11, without valid address
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checking net12, display name: NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter - VirtualBox Bridged Networking Driver Miniport
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] available addresses for net12 is: []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net12, child interfaces = java.net.NetworkInterface$1subIFs@6f110f5c)
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checkNetworkInterface(parent = net12) finished
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] sub address for net12 is []
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] found net12, without valid address
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] child network interface (net13,TAP-Win32 Adapter V9 - VirtualBox Bridged Networking Driver Miniport) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.031 [background-task-0-restart(0)] checking net14, display name: Carte USB D-Link DWA-140 RangeBooster N - VirtualBox Bridged Networking Driver Miniport
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] available addresses for net14 is: []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checkNetworkInterface(parent = net14, child interfaces = java.net.NetworkInterface$1subIFs@490799fb)
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checkNetworkInterface(parent = net14) finished
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] sub address for net14 is []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] found net14, without valid address
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] child network interface (net15,TAP-Win32 Adapter V9 - VirtualBox Bridged Networking Driver Miniport) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checking eth6, display name: Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] available addresses for eth6 is: []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checkNetworkInterface(parent = eth6, child interfaces = java.net.NetworkInterface$1subIFs@120e5332)
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checkNetworkInterface(parent = eth6) finished
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] sub address for eth6 is []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] found eth6, without valid address
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] child network interface (eth7,VirtualBox Host-Only Ethernet Adapter) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checking eth8, display name: SAMSUNG Mobile USB Remote NDIS Network Device
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] available addresses for eth8 is: []
TRACE 2013-11-05 16:39:20.032 [background-task-0-restart(0)] checkNetworkInterface(parent = eth8, child interfaces = java.net.NetworkInterface$1subIFs@6a7800e0)
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checkNetworkInterface(parent = eth8) finished
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] sub address for eth8 is []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] found eth8, without valid address
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checking eth9, display name: SAMSUNG Mobile USB Remote NDIS Network Device - VirtualBox Bridged Networking Driver Miniport
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] available addresses for eth9 is: []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checkNetworkInterface(parent = eth9, child interfaces = java.net.NetworkInterface$1subIFs@6c81a8bb)
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checkNetworkInterface(parent = eth9) finished
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] sub address for eth9 is []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] found eth9, without valid address
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checking eth10, display name: WAN Miniport (Network Monitor)-NetBalancer NDIS LightWeight Filter-0000
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] available addresses for eth10 is: []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checkNetworkInterface(parent = eth10, child interfaces = java.net.NetworkInterface$1subIFs@346cc4a4)
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checkNetworkInterface(parent = eth10) finished
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] sub address for eth10 is []
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] found eth10, without valid address
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] checking eth11, display name: WAN Miniport (Network Monitor)-QoS Packet Scheduler-0000
TRACE 2013-11-05 16:39:20.033 [background-task-0-restart(0)] available addresses for eth11 is: []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth11, child interfaces = java.net.NetworkInterface$1subIFs@50e205df)
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth11) finished
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] sub address for eth11 is []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] found eth11, without valid address
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checking eth12, display name: WAN Miniport (IP)-NetBalancer NDIS LightWeight Filter-0000
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] available addresses for eth12 is: []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth12, child interfaces = java.net.NetworkInterface$1subIFs@26ef9cf5)
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth12) finished
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] sub address for eth12 is []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] found eth12, without valid address
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checking eth13, display name: WAN Miniport (IP)-QoS Packet Scheduler-0000
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] available addresses for eth13 is: []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth13, child interfaces = java.net.NetworkInterface$1subIFs@3d29accb)
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checkNetworkInterface(parent = eth13) finished
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] sub address for eth13 is []
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] found eth13, without valid address
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] checking eth14, display name: WAN Miniport (IPv6)-NetBalancer NDIS LightWeight Filter-0000
TRACE 2013-11-05 16:39:20.034 [background-task-0-restart(0)] available addresses for eth14 is: []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth14, child interfaces = java.net.NetworkInterface$1subIFs@7b0f62cb)
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth14) finished
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] sub address for eth14 is []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] found eth14, without valid address
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checking eth15, display name: WAN Miniport (IPv6)-QoS Packet Scheduler-0000
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] available addresses for eth15 is: []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth15, child interfaces = java.net.NetworkInterface$1subIFs@2f1f3c8b)
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth15) finished
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] sub address for eth15 is []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] found eth15, without valid address
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] child network interface (eth16,VirtualBox Host-Only Ethernet Adapter-NetBalancer NDIS LightWeight Filter-0000) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] child network interface (eth17,VirtualBox Host-Only Ethernet Adapter-QoS Packet Scheduler-0000) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] child network interface (eth18,VirtualBox Host-Only Ethernet Adapter-WFP LightWeight Filter-0000) skipped, because skip_network_interfaces='[tap, vmnet, vnic, virtualbox]'
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checking eth19, display name: Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-NetBalancer NDIS LightWeight Filter-0000
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] available addresses for eth19 is: []
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth19, child interfaces = java.net.NetworkInterface$1subIFs@2bbfe1d8)
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] checkNetworkInterface(parent = eth19) finished
TRACE 2013-11-05 16:39:20.035 [background-task-0-restart(0)] sub address for eth19 is []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] found eth19, without valid address
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checking eth20, display name: Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-QoS Packet Scheduler-0000
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] available addresses for eth20 is: []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] non loopback/ipv4 addresses: []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checkNetworkInterface(parent = eth20, child interfaces = java.net.NetworkInterface$1subIFs@42844258)
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checkNetworkInterface(parent = eth20) finished
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] sub address for eth20 is []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] found eth20, without valid address
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checking eth21, display name: Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-WFP LightWeight Filter-0000
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] available addresses for eth21 is: []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checkNetworkInterface(parent = eth21, child interfaces = java.net.NetworkInterface$1subIFs@791fc185)
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checkNetworkInterface(parent = eth21) finished
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] sub address for eth21 is []
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] found eth21, without valid address
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] checkNetworkInterface(parent = null) finished
TRACE 2013-11-05 16:39:20.036 [background-task-0-restart(0)] default network interface address from [InterfaceAssociation(addr=null, iface=name:lo (Software Loopback Interface 1), parent=null), InterfaceAssociation(addr=null, iface=name:net0 (WAN Miniport (SSTP)), parent=null), InterfaceAssociation(addr=null, iface=name:net1 (WAN Miniport (L2TP)), parent=null), InterfaceAssociation(addr=null, iface=name:net2 (WAN Miniport (PPTP)), parent=null), InterfaceAssociation(addr=null, iface=name:ppp0 (WAN Miniport (PPPOE)), parent=null), InterfaceAssociation(addr=null, iface=name:eth0 (WAN Miniport (IPv6)), parent=null), InterfaceAssociation(addr=null, iface=name:eth1 (WAN Miniport (Network Monitor)), parent=null), InterfaceAssociation(addr=null, iface=name:eth2 (WAN Miniport (IP)), parent=null), InterfaceAssociation(addr=null, iface=name:ppp1 (RAS Async Adapter), parent=null), InterfaceAssociation(addr=null, iface=name:net3 (WAN Miniport (IKEv2)), parent=null), InterfaceAssociation(addr=/192.168.1.89, iface=name:eth3 (Realtek PCIe GBE Family Controller), parent=null), InterfaceAssociation(addr=null, iface=name:net4 (Carte Microsoft ISATAP), parent=null), InterfaceAssociation(addr=null, iface=name:net5 (Teredo Tunneling Pseudo-Interface), parent=null), InterfaceAssociation(addr=null, iface=name:net6 (Carte Microsoft ISATAP #2), parent=null), InterfaceAssociation(addr=null, iface=name:net7 (Carte Microsoft ISATAP #3), parent=null), InterfaceAssociation(addr=null, iface=name:net8 (Carte USB D-Link DWA-140 RangeBooster N), parent=null), InterfaceAssociation(addr=null, iface=name:net9 (Carte Microsoft ISATAP #4), parent=null), InterfaceAssociation(addr=null, iface=name:net10 (Carte Microsoft ISATAP #5), parent=null), InterfaceAssociation(addr=null, iface=name:net11 (NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter), parent=null), InterfaceAssociation(addr=null, iface=name:net12 (NETGEAR WNDA4100 N900 Wireless Dual Band USB Adapter - VirtualBox Bridged Networking Driver Miniport), parent=null), InterfaceAssociation(addr=null, iface=name:net14 (Carte USB D-Link DWA-140 RangeBooster N - VirtualBox Bridged Networking Driver Miniport), parent=null), InterfaceAssociation(addr=null, iface=name:eth6 (Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport), parent=null), InterfaceAssociation(addr=null, iface=name:eth8 (SAMSUNG Mobile USB Remote NDIS Network Device), parent=null), InterfaceAssociation(addr=null, iface=name:eth9 (SAMSUNG Mobile USB Remote NDIS Network Device - VirtualBox Bridged Networking Driver Miniport), parent=null), InterfaceAssociation(addr=null, iface=name:eth10 (WAN Miniport (Network Monitor)-NetBalancer NDIS LightWeight Filter-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth11 (WAN Miniport (Network Monitor)-QoS Packet Scheduler-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth12 (WAN Miniport (IP)-NetBalancer NDIS LightWeight Filter-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth13 (WAN Miniport (IP)-QoS Packet Scheduler-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth14 (WAN Miniport (IPv6)-NetBalancer NDIS LightWeight Filter-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth15 (WAN Miniport (IPv6)-QoS Packet Scheduler-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth19 (Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-NetBalancer NDIS LightWeight Filter-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth20 (Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-QoS Packet Scheduler-0000), parent=null), InterfaceAssociation(addr=null, iface=name:eth21 (Realtek PCIe GBE Family Controller - VirtualBox Bridged Networking Driver Miniport-WFP LightWeight Filter-0000), parent=null)]
TRACE 2013-11-05 16:39:20.037 [background-task-0-restart(0)] first network interface: InterfaceAssociation(addr=/192.168.1.89, iface=name:eth3 (Realtek PCIe GBE Family Controller), parent=null)
INFO 2013-11-05 16:39:20.037 [background-task-0-restart(0)] Using address /192.168.1.89 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO 2013-11-05 16:39:20.037 [background-task-0-restart(0)] Created socket: /192.168.1.89:5001
DEBUG 2013-11-05 16:39:20.052 [background-task-0-restart(0)] Sending ALIVE...
TRACE 2013-11-05 16:39:20.221 [background-task-0-restart(0)] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:39:20.221 [background-task-0-restart(0)] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:39:20.221 [background-task-0-restart(0)] Socket Timeout: 0
TRACE 2013-11-05 16:39:20.221 [background-task-0-restart(0)] Socket TTL: 32
TRACE 2013-11-05 16:39:20.222 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:64205]
DEBUG 2013-11-05 16:39:20.222 [background-task-0-restart(0)] task ended
DEBUG 2013-11-05 16:39:21.515 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:39:21.690 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:39:21.690 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:39:21.690 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:39:21.691 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:39:21.691 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:64206]
DEBUG 2013-11-05 16:39:41.691 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:39:41.858 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:39:41.858 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:39:41.858 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:39:41.858 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:39:41.858 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:57301]
TRACE 2013-11-05 16:39:41.859 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:57301]
TRACE 2013-11-05 16:40:02.812 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:40:02.813 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:40:02.818 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
INFO 2013-11-05 16:40:37.708 [UPNPHelper] No IP filter specified, access granted to /192.168.1.89
TRACE 2013-11-05 16:40:37.709 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:37.710 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:37.711 [UPNPHelper] Sending this reply [192.168.1.89:54094]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 05 Nov 2013 15:40:37 GMT<CRLF>LOCATION: http://192.168.1.89:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:020d6374-8248-4298-a8bc-fcbddb6aff6b::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-05 16:40:37.713 [New I/O server boss #18] Creating new pipeline
TRACE 2013-11-05 16:40:37.760 [New I/O worker #10] Opened request handler on socket /192.168.1.89:53904
TRACE 2013-11-05 16:40:37.764 [New I/O worker #10] Request: HTTP/1.1 : GET : description/fetch
TRACE 2013-11-05 16:40:37.765 [New I/O worker #10] Received on socket: Accept: text/xml, application/xml
TRACE 2013-11-05 16:40:37.765 [New I/O worker #10] Received on socket: Cache-Control: no-cache
TRACE 2013-11-05 16:40:37.766 [New I/O worker #10] Received on socket: Connection: Close
TRACE 2013-11-05 16:40:37.766 [New I/O worker #10] Received on socket: Host: 192.168.1.89:5001
TRACE 2013-11-05 16:40:37.766 [New I/O worker #10] Received on socket: Pragma: no-cache
TRACE 2013-11-05 16:40:37.767 [New I/O worker #10] Received on socket: User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
INFO 2013-11-05 16:40:37.771 [pool-8-thread-1] Checking IP: 192.168.1.89 for WMP
INFO 2013-11-05 16:40:37.782 [pool-8-thread-1] Renderer WMP found on this address: Kirvx-PC.bouyguesbox.fr (192.168.1.89)
TRACE 2013-11-05 16:40:37.789 [New I/O worker #10] Matched media renderer "WMP" based on header "User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50"
DEBUG 2013-11-05 16:40:37.789 [New I/O worker #10] HTTP User-Agent: Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
TRACE 2013-11-05 16:40:37.789 [New I/O worker #10] Recognized media renderer: WMP
TRACE 2013-11-05 16:40:37.789 [New I/O worker #10] HTTP: description/fetch / 0-0
DEBUG 2013-11-05 16:40:37.791 [pool-8-thread-1] Starting ping -n 3 -l 64000 192.168.1.89
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Cache-Control: no-cache
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Connection: keep-alive
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Content-Length: 3046
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Expires: 0
TRACE 2013-11-05 16:40:37.807 [New I/O worker #10] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0
DEBUG 2013-11-05 16:40:37.816 [Thread-14]
DEBUG 2013-11-05 16:40:37.816 [Thread-14] Envoi d'une requ�te 'Ping' 192.168.1.89 avec 64000 octets de donn�es�:
DEBUG 2013-11-05 16:40:37.816 [Thread-14] R�ponse de 192.168.1.89�: octets=64000 temps<1ms TTL=128
TRACE 2013-11-05 16:40:37.878 [New I/O server boss #18] Creating new pipeline
TRACE 2013-11-05 16:40:37.880 [New I/O worker #11] Opened request handler on socket /192.168.1.89:53912
TRACE 2013-11-05 16:40:37.880 [New I/O worker #11] Request: HTTP/1.1 : GET : images/icon-48.png
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] Matched media renderer "WMP" based on address /192.168.1.89
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] Received on socket: Connection: Keep-Alive
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] Received on socket: Host: 192.168.1.89:5001
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] Received on socket: User-Agent: Windows-Media-Player-DMS/12.0.7601.17514
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] Recognized media renderer: WMP
TRACE 2013-11-05 16:40:37.881 [New I/O worker #11] HTTP: images/icon-48.png / 0-0
TRACE 2013-11-05 16:40:37.882 [New I/O worker #11] Available Content-Length: 6141
TRACE 2013-11-05 16:40:37.885 [New I/O worker #11] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-05 16:40:37.886 [New I/O worker #11] Sent to socket: Connection: keep-alive
TRACE 2013-11-05 16:40:37.886 [New I/O worker #11] Sent to socket: Content-Length: 6141
TRACE 2013-11-05 16:40:37.886 [New I/O worker #11] Sent to socket: Content-Type: image/png
TRACE 2013-11-05 16:40:37.886 [New I/O worker #11] Sent to socket: Expires: Sat, 01 Mar 2014 09:27:17 GMT
TRACE 2013-11-05 16:40:37.886 [New I/O worker #11] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0
DEBUG 2013-11-05 16:40:38.816 [Thread-14] R�ponse de 192.168.1.89�: octets=64000 temps<1ms TTL=128
DEBUG 2013-11-05 16:40:39.791 [SpeedStats Failsafe] Stopping process: ping-0
INFO 2013-11-05 16:40:39.794 [pool-8-thread-1] Address /192.168.1.89 has an estimated network speed of: 1024 Mb/s
TRACE 2013-11-05 16:40:40.708 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:40.709 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:40.709 [UPNPHelper] Sending this reply [192.168.1.89:54094]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 05 Nov 2013 15:40:40 GMT<CRLF>LOCATION: http://192.168.1.89:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:020d6374-8248-4298-a8bc-fcbddb6aff6b::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-05 16:40:43.709 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:43.710 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:40:43.710 [UPNPHelper] Sending this reply [192.168.1.89:54094]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 05 Nov 2013 15:40:43 GMT<CRLF>LOCATION: http://192.168.1.89:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0<CRLF>ST: urn:schemas-upnp-org:device:MediaServer:1<CRLF>EXT: <CRLF>USN: uuid:020d6374-8248-4298-a8bc-fcbddb6aff6b::urn:schemas-upnp-org:device:MediaServer:1<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-05 16:41:02.871 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:41:10.957 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:11.252 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:11.375 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:11.641 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:12.078 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:13.416 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:13.976 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:14.260 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:14.403 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:14.667 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:15.093 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:41:19.432 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:42:02.929 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:42:21.156 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:42:24.156 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:42:27.157 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:54094]
TRACE 2013-11-05 16:42:31.115 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.89:58773]
TRACE 2013-11-05 16:42:31.116 [UPNPHelper] Sending this reply [192.168.1.89:58773]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 05 Nov 2013 15:42:31 GMT<CRLF>LOCATION: http://192.168.1.89:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0<CRLF>ST: upnp:rootdevice<CRLF>EXT: <CRLF>USN: uuid:020d6374-8248-4298-a8bc-fcbddb6aff6b::upnp:rootdevice<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-05 16:42:31.121 [New I/O server boss #18] Creating new pipeline
TRACE 2013-11-05 16:42:31.122 [New I/O worker #12] Opened request handler on socket /192.168.1.89:53924
TRACE 2013-11-05 16:42:31.122 [New I/O worker #12] Request: HTTP/1.1 : GET : description/fetch
TRACE 2013-11-05 16:42:31.123 [New I/O worker #12] Matched media renderer "WMP" based on address /192.168.1.89
TRACE 2013-11-05 16:42:31.123 [New I/O worker #12] Received on socket: Connection: close
TRACE 2013-11-05 16:42:31.123 [New I/O worker #12] Received on socket: Host: 192.168.1.89:5001
TRACE 2013-11-05 16:42:31.123 [New I/O worker #12] Recognized media renderer: WMP
TRACE 2013-11-05 16:42:31.123 [New I/O worker #12] HTTP: description/fetch / 0-0
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Accept-Ranges: bytes
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Cache-Control: no-cache
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Connection: keep-alive
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Content-Length: 3046
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Content-Type: text/xml; charset="utf-8"
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Expires: 0
TRACE 2013-11-05 16:42:31.125 [New I/O worker #12] Sent to socket: Server: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0
DEBUG 2013-11-05 16:42:41.859 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:42:42.022 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:42:42.022 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:42:42.023 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:42:42.023 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:42:42.023 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:61473]
TRACE 2013-11-05 16:43:02.989 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:44:03.047 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:45:03.106 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:45:03.107 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
DEBUG 2013-11-05 16:45:42.024 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:45:42.189 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:45:42.189 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:45:42.189 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:45:42.189 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:45:42.190 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:51522]
TRACE 2013-11-05 16:46:03.166 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:46:03.167 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:48:03.283 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:48:34.970 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:35.256 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:35.398 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:35.698 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:36.115 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:37.420 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:37.969 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:38.256 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:38.398 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:38.690 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:39.115 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:40.420 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:40.970 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:41.256 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:41.398 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:41.690 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:48:42.114 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
DEBUG 2013-11-05 16:48:42.190 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:48:42.359 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:48:42.359 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:48:42.360 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:48:42.360 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:48:42.360 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:62346]
TRACE 2013-11-05 16:48:43.421 [UPNPHelper] Receiving a NOTIFY from [192.168.1.62:1900]
TRACE 2013-11-05 16:49:03.341 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:50:03.399 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:50:03.400 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:51:03.457 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
DEBUG 2013-11-05 16:51:42.360 [UPNP-AliveMessageSender] Sending ALIVE...
TRACE 2013-11-05 16:51:42.546 [UPNP-AliveMessageSender] Sending message from multicast socket on network interface: name:null
TRACE 2013-11-05 16:51:42.546 [UPNP-AliveMessageSender] Multicast socket is on interface: /0.0.0.0
TRACE 2013-11-05 16:51:42.546 [UPNP-AliveMessageSender] Socket Timeout: 0
TRACE 2013-11-05 16:51:42.546 [UPNP-AliveMessageSender] Socket TTL: 32
TRACE 2013-11-05 16:51:42.547 [UPNPHelper] Receiving a NOTIFY from [192.168.1.89:53924]
TRACE 2013-11-05 16:52:03.518 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:52:03.523 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
INFO 2013-11-05 16:52:29.774 [UPNPHelper] No IP filter specified, access granted to /192.168.1.62
TRACE 2013-11-05 16:52:29.775 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.62:62884]
TRACE 2013-11-05 16:52:32.775 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.62:62884]
TRACE 2013-11-05 16:52:35.774 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.62:62884]
TRACE 2013-11-05 16:52:39.738 [UPNPHelper] Receiving a M-SEARCH from [192.168.1.62:49789]
TRACE 2013-11-05 16:52:39.739 [UPNPHelper] Sending this reply [192.168.1.62:49789]: HTTP/1.1 200 OK<CRLF>CACHE-CONTROL: max-age=1200<CRLF>DATE: Tue, 05 Nov 2013 15:52:39 GMT<CRLF>LOCATION: http://192.168.1.89:5001/description/fetch<CRLF>SERVER: Windows_7-amd64-6.1, UPnP/1.0, UMS/3.0.0<CRLF>ST: upnp:rootdevice<CRLF>EXT: <CRLF>USN: uuid:020d6374-8248-4298-a8bc-fcbddb6aff6b::upnp:rootdevice<CRLF>Content-Length: 0<CRLF><CRLF>
TRACE 2013-11-05 16:53:03.577 [UPNPHelper] Receiving a NOTIFY from [192.168.1.23:1900]
TRACE 2013-11-05 16:53:06.462 [UPNPHelper] Receiving a NOTIFY from [192.168.1.254:32770]
TRACE 2013-11-05 16:53:06.467 [UPNPHelper] Receiving a NOTIFY from [192.168.1.254:32770]
