Background and foreground color of UMS 7.5.0 main panel log viewer
The background color of the UMS 7.5.0 main panel log viewer on the "Logs" tab is specifically defined as white while the foreground color uses the system's "disabled text" color. To eliminate problems where a foreground color is invisible against the white background, please either specify all the foreground color types with the background color, or not specify any and let the program get all color values from the system. Thanks
