[Solved] Minimized at start on MacOS
Seryon
Post by Seryon »
Dear all,
First of all thanks for your amazing software that provides me with countless hours of entertainment!
Can you please advise whether the minimization at startup is back on MacOS after taken away with 7.4.0?
I installed the last 7.6.2 version (from the dmg, I always just overwrite the previous file) and seems still not to be able to minimize at startup (which would be super cool as I have a script running that restarts it when I WakeUp the mac and I’d love not having to close the window!)
Thanks a lot and once again... kudos from Italy!
Alberto
EnumOlive
Re: Minimized at start on MacOS
Post by EnumOlive »
Hi Alberto
Thanks for your support!
The minimization at startup was causing issues for some users where the window would never show up and so it was removed.
Seryon
Re: [Solved] Minimized at start on MacOS
Post by Seryon »
Thanks! I will now remove the post from the Mac OS board ;)
I am a long time mac user, and to be honest I never noticed such behavior.
Do you fell you'll be able to re-introduce it leaving the option to the users?
Have a great day!
Alberto
Hi Alberto,
I would love to reintroduce a more stable implementation of the minimized start feature at some stage, but I don't think we will put back the old one, since it completely stops the program from being usable in that case (and I reproduced that bug myself).
Maybe you could submit a better implementation to us via GitHub :)
