Unknown IP address connecting to java while running UMS
Alextazy69
Post by Alextazy69 »
Im trying to solve a problem that the UMS doesnt recognize my render, and i noticed that while my render does not show but an foregin address does menage to connect to "Javaw" service (151.101.12.133 , 151.101.112.133 "raw.github.com") with the port 443.
Is this the connection for the software the check updates?
EnumOlive
Re: Unknown IP address connecting to java while running UMS
Post by EnumOlive »
Hi
Please follow the instructions for Problem Reporting Guidelines
You will need to enable TRACE which will restart in a mode which gives us more information. Then you can follow the instructions to pack and upload to this thread.
You could also try manually setting the network interface.
Go to the General Configuration tab and under Network Settings (Advanced) use the dropdown for Force networking on interface: to choose your local network.
Please let us know if this works for you.
