samsung smart tv
samsung smart tv
all new update, you do,it not working anymore on my samsung smart tv
my samsung tv does not find UMC
tha last version that work on my tv is version UMS 7.4.0 so i stick with this version for now....
can you fix this!!!
can you fix this!!!
Re: samsung smart tv
Hi tv4k
It would be useful if you could switch to the version that is not working for you and follow the instructions for attaching your debug information as explained in the Problem Reporting Guidelines
working version
let try version 7.8.0 ( working now?)
seem to work now
seem to work now
working now?DEBUG 2019-01-19 20:55:01.101 [main] Default logfile folder set to: C:\ProgramData\UMS
DEBUG 2019-01-19 20:55:01.153 [main] LogBack started with configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
DEBUG 2019-01-19 20:55:01.154 [main] Reading logging_filter_logs_tab: "TRACE" (default: "INFO")
DEBUG 2019-01-19 20:55:01.159 [main] Starting services
DEBUG 2019-01-19 20:55:01.159 [main] Starting ProcessManager
DEBUG 2019-01-19 20:55:01.160 [Process Terminator] ProcessTerminator is starting
DEBUG 2019-01-19 20:55:01.161 [main] Starting SleepManager
DEBUG 2019-01-19 20:55:01.163 [main] Sat Jan 19 20:55:01 EST 2019
DEBUG 2019-01-19 20:55:01.233 [main] Writing PID: 3128
DEBUG 2019-01-19 20:55:01.237 [main] Reading show_splash_screen: false (default: true)
INFO 2019-01-19 20:55:01.237 [main] Starting Universal Media Server 7.8.0
INFO 2019-01-19 20:55:01.238 [main] Based on PS3 Media Server by shagrath, copyright 2008-2014
INFO 2019-01-19 20:55:01.238 [main] https://www.universalmediaserver.com
INFO 2019-01-19 20:55:01.238 [main] Build: d960a076a (2019-01-12)
INFO 2019-01-19 20:55:01.238 [main] Java: Java HotSpot(TM) 64-Bit Server VM 1.8.0_181 (64-bit) by Oracle Corporation
INFO 2019-01-19 20:55:01.238 [main] OS: Windows 7 64-bit 6.1
INFO 2019-01-19 20:55:01.240 [main] Maximum JVM Memory: 1.1 GiB
INFO 2019-01-19 20:55:01.242 [main] Language: English (United States)
INFO 2019-01-19 20:55:01.243 [main] Encoding: UTF-8
INFO 2019-01-19 20:55:01.243 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO 2019-01-19 20:55:01.247 [main] Temporary directory: C:\Users\i7\AppData\Local\Temp\UMS
INFO 2019-01-19 20:55:01.248 [main] Logging configuration file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO 2019-01-19 20:55:01.248 [main] Logfile: C:\ProgramData\UMS\debug.log
INFO 2019-01-19 20:55:01.248 [main] Profile directory: C:\ProgramData\UMS
INFO 2019-01-19 20:55:01.249 [main] Profile directory permissions: drwx
INFO 2019-01-19 20:55:01.249 [main] Profile configuration file: C:\ProgramData\UMS\UMS.conf
INFO 2019-01-19 20:55:01.250 [main] Profile configuration file permissions: -rwx
INFO 2019-01-19 20:55:01.250 [main] Profile name: i7pc
DEBUG 2019-01-19 20:55:01.250 [main] Reading web_conf: "C:\ProgramData\UMS\WEB.conf" (previous: null, default: "C:\ProgramData\UMS\WEB.conf")
INFO 2019-01-19 20:55:01.250 [main] Web configuration file: C:\ProgramData\UMS\WEB.conf
INFO 2019-01-19 20:55:01.251 [main] Web configuration file permissions: -rwx
DEBUG 2019-01-19 20:55:01.259 [main] Using database URL: jdbc:h2:C:\ProgramData\UMS\database\medias
INFO 2019-01-19 20:55:01.259 [main] Using database located at: "C:\ProgramData\UMS\database"
DEBUG 2019-01-19 20:55:01.259 [main] Database logging is disabled
DEBUG 2019-01-19 20:55:01.370 [main] Database file count: 166
DEBUG 2019-01-19 20:55:01.370 [main] Database version: 18
DEBUG 2019-01-19 20:55:01.370 [main] Starting check of database tables
DEBUG 2019-01-19 20:55:01.378 [main] Reading run_wizard: false (default: true)
DEBUG 2019-01-19 20:55:01.403 [main] Reading hide_advanced_options: false (default: true)
DEBUG 2019-01-19 20:55:01.775 [main] Reading network_interface: "eth3" (default: "")
DEBUG 2019-01-19 20:55:01.777 [main] Reading maximum_bitrate: "0" (default: "90")
INFO 2019-01-19 20:55:01.801 [main] Checking shared folder: "H:\here"
INFO 2019-01-19 20:55:01.802 [main] Checking shared folder: "E:\tv"
WARN 2019-01-19 20:55:01.802 [main] "E:\tv" does not exist. Please remove it from your shared folders list on the "Navigation/Share Settings" tab or in the configuration file.
INFO 2019-01-19 20:55:01.802 [main] Checking shared folder: "F:\files"
INFO 2019-01-19 20:55:01.802 [main] Checking shared folder: "E:\cine"
DEBUG 2019-01-19 20:55:01.803 [main] "E:\tv" does not exist - check the configuration for key "folders_monitored"
DEBUG 2019-01-19 20:55:01.815 [main] Reading mpeg2_main_settings: "keyint=5:vqscale=1:vqmin=1" (default: "Automatic (Wired)")
DEBUG 2019-01-19 20:55:01.817 [main] Reading x264_constant_rate_factor: "16" (default: "Automatic (Wired)")
DEBUG 2019-01-19 20:55:01.819 [main] Reading audio_use_pcm: true (default: false)
DEBUG 2019-01-19 20:55:01.820 [main] Reading audio_embed_dts_in_pcm: true (default: false)
DEBUG 2019-01-19 20:55:01.829 [main] Reading autoload_external_subtitles: false (default: true)
DEBUG 2019-01-19 20:55:01.830 [main] Reading force_external_subtitles: false (default: true)
DEBUG 2019-01-19 20:55:02.018 [main] Checking dbgpack property in UMS.conf
DEBUG 2019-01-19 20:55:02.022 [main] Reading uuid: "66b2cd50-dbb8-4492-9a68-7df0c717ec63" (default: null)
INFO 2019-01-19 20:55:02.022 [main] Using the following UUID configured in UMS.conf: 66b2cd50-dbb8-4492-9a68-7df0c717ec63
DEBUG 2019-01-19 20:55:02.023 [main] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2019-01-19 20:55:02.023 [main] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2019-01-19 20:55:02.023 [main] adding C:\ProgramData\UMS\debug.log.prev
DEBUG 2019-01-19 20:55:02.028 [main] Added file watch at C:\ProgramData\UMS: C:\\ProgramData\\UMS\\UMS.cred
INFO 2019-01-19 20:55:02.031 [main] Loading MediaInfo library
INFO 2019-01-19 20:55:02.034 [main] Loaded MediaInfoLib - v18.12
DEBUG 2019-01-19 20:55:02.035 [main] Setting MediaInfo library characterset to UTF-8
DEBUG 2019-01-19 20:55:02.035 [main] Option 'File_TestContinuousFileNames' is set to: 0
DEBUG 2019-01-19 20:55:02.035 [main] Option 'ParseSpeed' is set to: 0.000
INFO 2019-01-19 20:55:02.037 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
DEBUG 2019-01-19 20:55:02.039 [main] Added file watch at renderers: renderers\\AnyCast.conf
DEBUG 2019-01-19 20:55:02.040 [main] Added file watch at renderers: renderers\\Apple-iDevice-AirPlayer.conf
DEBUG 2019-01-19 20:55:02.042 [main] Added file watch at renderers: renderers\\Apple-iDevice-VLC.conf
DEBUG 2019-01-19 20:55:02.043 [main] Added file watch at renderers: renderers\\Apple-iDevice-VLC32bit.conf
DEBUG 2019-01-19 20:55:02.044 [main] Added file watch at renderers: renderers\\Apple-iDevice.conf
DEBUG 2019-01-19 20:55:02.045 [main] Added file watch at renderers: renderers\\Apple-TV-VLC.conf
DEBUG 2019-01-19 20:55:02.047 [main] Added file watch at renderers: renderers\\BlackBerry-PlayBook-KalemSoftMP.conf
DEBUG 2019-01-19 20:55:02.048 [main] Added file watch at renderers: renderers\\Bush-FreeviewHighDefinitionDigitalSetTopBox.conf
DEBUG 2019-01-19 20:55:02.049 [main] Added file watch at renderers: renderers\\CambridgeAudio-AzurBD.conf
DEBUG 2019-01-19 20:55:02.052 [main] Added file watch at renderers: renderers\\DefaultRenderer.conf
DEBUG 2019-01-19 20:55:02.054 [main] Added file watch at renderers: renderers\\DirecTV.conf
DEBUG 2019-01-19 20:55:02.055 [main] Added file watch at renderers: renderers\\DLink-DSM510.conf
DEBUG 2019-01-19 20:55:02.056 [main] Added file watch at renderers: renderers\\FetchTV.conf
DEBUG 2019-01-19 20:55:02.057 [main] Added file watch at renderers: renderers\\Free-Freebox.conf
DEBUG 2019-01-19 20:55:02.057 [main] Added file watch at renderers: renderers\\Freecom-MusicPal.conf
DEBUG 2019-01-19 20:55:02.059 [main] Added file watch at renderers: renderers\\Google-Android-BubbleUPnP-MXPlayer.conf
DEBUG 2019-01-19 20:55:02.060 [main] Added file watch at renderers: renderers\\Google-Android-Chromecast.conf
DEBUG 2019-01-19 20:55:02.061 [main] Added file watch at renderers: renderers\\Google-Android.conf
DEBUG 2019-01-19 20:55:02.062 [main] Added file watch at renderers: renderers\\Google-ChromecastUltra.conf
DEBUG 2019-01-19 20:55:02.063 [main] Added file watch at renderers: renderers\\Hama-IR320.conf
DEBUG 2019-01-19 20:55:02.064 [main] Added file watch at renderers: renderers\\Hisense-K680.conf
DEBUG 2019-01-19 20:55:02.065 [main] Added file watch at renderers: renderers\\Kodi.conf
DEBUG 2019-01-19 20:55:02.066 [main] Added file watch at renderers: renderers\\LG-BP.conf
DEBUG 2019-01-19 20:55:02.067 [main] Added file watch at renderers: renderers\\LG-BP550.conf
DEBUG 2019-01-19 20:55:02.068 [main] Added file watch at renderers: renderers\\LG-EG910V.conf
DEBUG 2019-01-19 20:55:02.069 [main] Added file watch at renderers: renderers\\LG-LA6200.conf
DEBUG 2019-01-19 20:55:02.070 [main] Added file watch at renderers: renderers\\LG-LA644V.conf
DEBUG 2019-01-19 20:55:02.070 [main] Added file watch at renderers: renderers\\LG-LB.conf
DEBUG 2019-01-19 20:55:02.071 [main] Added file watch at renderers: renderers\\LG-LM620.conf
DEBUG 2019-01-19 20:55:02.072 [main] Added file watch at renderers: renderers\\LG-LM660.conf
DEBUG 2019-01-19 20:55:02.073 [main] Added file watch at renderers: renderers\\LG-LS5700.conf
DEBUG 2019-01-19 20:55:02.074 [main] Added file watch at renderers: renderers\\LG-ST600.conf
DEBUG 2019-01-19 20:55:02.075 [main] Added file watch at renderers: renderers\\LG-UB820V.conf
DEBUG 2019-01-19 20:55:02.075 [main] Added file watch at renderers: renderers\\LG-WebOS.conf
DEBUG 2019-01-19 20:55:02.076 [main] Added file watch at renderers: renderers\\Logitech-Squeezebox.conf
DEBUG 2019-01-19 20:55:02.077 [main] Added file watch at renderers: renderers\\Microsoft-WindowsMediaPlayer.conf
DEBUG 2019-01-19 20:55:02.078 [main] Added file watch at renderers: renderers\\Microsoft-Xbox360.conf
DEBUG 2019-01-19 20:55:02.078 [main] Added file watch at renderers: renderers\\Microsoft-XboxOne.conf
DEBUG 2019-01-19 20:55:02.079 [main] Added file watch at renderers: renderers\\Miracast-M806.conf
DEBUG 2019-01-19 20:55:02.080 [main] Added file watch at renderers: renderers\\Naim-Mu-So.conf
DEBUG 2019-01-19 20:55:02.080 [main] Added file watch at renderers: renderers\\Netgear-NeoTV.conf
DEBUG 2019-01-19 20:55:02.081 [main] Added file watch at renderers: renderers\\Netgem-N7700.conf
DEBUG 2019-01-19 20:55:02.081 [main] Added file watch at renderers: renderers\\Nokia-N900.conf
DEBUG 2019-01-19 20:55:02.082 [main] Added file watch at renderers: renderers\\Onkyo-TXNR7xx.conf
DEBUG 2019-01-19 20:55:02.083 [main] Added file watch at renderers: renderers\\Onkyo-TXNR8xx.conf
DEBUG 2019-01-19 20:55:02.083 [main] Added file watch at renderers: renderers\\OPPO-BDP.conf
DEBUG 2019-01-19 20:55:02.084 [main] Added file watch at renderers: renderers\\OPPO-BDP83.conf
DEBUG 2019-01-19 20:55:02.085 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT.conf
DEBUG 2019-01-19 20:55:02.085 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT220.conf
DEBUG 2019-01-19 20:55:02.086 [main] Added file watch at renderers: renderers\\Panasonic-DMPBDT360.conf
DEBUG 2019-01-19 20:55:02.087 [main] Added file watch at renderers: renderers\\Panasonic-DMR.conf
DEBUG 2019-01-19 20:55:02.088 [main] Added file watch at renderers: renderers\\Panasonic-SCBTT.conf
DEBUG 2019-01-19 20:55:02.088 [main] Added file watch at renderers: renderers\\Panasonic-Viera.conf
DEBUG 2019-01-19 20:55:02.089 [main] Added file watch at renderers: renderers\\Panasonic-VieraAS600E.conf
DEBUG 2019-01-19 20:55:02.090 [main] Added file watch at renderers: renderers\\Panasonic-VieraAS650.conf
DEBUG 2019-01-19 20:55:02.091 [main] Added file watch at renderers: renderers\\Panasonic-VieraCX680.conf
DEBUG 2019-01-19 20:55:02.092 [main] Added file watch at renderers: renderers\\Panasonic-VieraCX700.conf
DEBUG 2019-01-19 20:55:02.092 [main] Added file watch at renderers: renderers\\Panasonic-VieraDX.conf
DEBUG 2019-01-19 20:55:02.093 [main] Added file watch at renderers: renderers\\Panasonic-VieraE6.conf
DEBUG 2019-01-19 20:55:02.094 [main] Added file watch at renderers: renderers\\Panasonic-VieraET60.conf
DEBUG 2019-01-19 20:55:02.095 [main] Added file watch at renderers: renderers\\Panasonic-VieraGT50.conf
DEBUG 2019-01-19 20:55:02.096 [main] Added file watch at renderers: renderers\\Panasonic-VieraS60.conf
DEBUG 2019-01-19 20:55:02.096 [main] Added file watch at renderers: renderers\\Panasonic-VieraST60.conf
DEBUG 2019-01-19 20:55:02.097 [main] Added file watch at renderers: renderers\\Panasonic-VieraTHPU30Z.conf
DEBUG 2019-01-19 20:55:02.098 [main] Added file watch at renderers: renderers\\Panasonic-VieraTXL32V10E.conf
DEBUG 2019-01-19 20:55:02.099 [main] Added file watch at renderers: renderers\\Panasonic-VieraVT60.conf
DEBUG 2019-01-19 20:55:02.100 [main] Added file watch at renderers: renderers\\Philips-AureaAndNetTV.conf
DEBUG 2019-01-19 20:55:02.100 [main] Added file watch at renderers: renderers\\Philips-PFL.conf
DEBUG 2019-01-19 20:55:02.101 [main] Added file watch at renderers: renderers\\Philips-PUS.conf
DEBUG 2019-01-19 20:55:02.102 [main] Added file watch at renderers: renderers\\Philips-Streamium.conf
DEBUG 2019-01-19 20:55:02.103 [main] Added file watch at renderers: renderers\\Pioneer-BDP.conf
DEBUG 2019-01-19 20:55:02.103 [main] Added file watch at renderers: renderers\\Pioneer-Kuro.conf
DEBUG 2019-01-19 20:55:02.104 [main] Added file watch at renderers: renderers\\PopcornHour.conf
DEBUG 2019-01-19 20:55:02.105 [main] Added file watch at renderers: renderers\\Realtek.conf
DEBUG 2019-01-19 20:55:02.105 [main] Added file watch at renderers: renderers\\Roku-Roku3-3.conf
DEBUG 2019-01-19 20:55:02.106 [main] Added file watch at renderers: renderers\\Roku-Roku3-5.conf
DEBUG 2019-01-19 20:55:02.107 [main] Added file watch at renderers: renderers\\Roku-Roku3-6-7.conf
DEBUG 2019-01-19 20:55:02.108 [main] Added file watch at renderers: renderers\\Roku-TV8.conf
DEBUG 2019-01-19 20:55:02.109 [main] Added file watch at renderers: renderers\\Samsung-8series.conf
DEBUG 2019-01-19 20:55:02.110 [main] Added file watch at renderers: renderers\\Samsung-9series.conf
DEBUG 2019-01-19 20:55:02.111 [main] Added file watch at renderers: renderers\\Samsung-BDC6800.conf
DEBUG 2019-01-19 20:55:02.112 [main] Added file watch at renderers: renderers\\Samsung-BDH6500.conf
DEBUG 2019-01-19 20:55:02.113 [main] Added file watch at renderers: renderers\\Samsung-C6600.conf
DEBUG 2019-01-19 20:55:02.113 [main] Added file watch at renderers: renderers\\Samsung-CD.conf
DEBUG 2019-01-19 20:55:02.114 [main] Added file watch at renderers: renderers\\Samsung-D6400.conf
DEBUG 2019-01-19 20:55:02.115 [main] Added file watch at renderers: renderers\\Samsung-D7000.conf
DEBUG 2019-01-19 20:55:02.116 [main] Added file watch at renderers: renderers\\Samsung-EH5300.conf
DEBUG 2019-01-19 20:55:02.116 [main] Added file watch at renderers: renderers\\Samsung-EH6070.conf
DEBUG 2019-01-19 20:55:02.117 [main] Added file watch at renderers: renderers\\Samsung-ES6100.conf
DEBUG 2019-01-19 20:55:02.118 [main] Added file watch at renderers: renderers\\Samsung-ES6575.conf
DEBUG 2019-01-19 20:55:02.119 [main] Added file watch at renderers: renderers\\Samsung-ES8000.conf
DEBUG 2019-01-19 20:55:02.120 [main] Added file watch at renderers: renderers\\Samsung-ES8005.conf
DEBUG 2019-01-19 20:55:02.121 [main] Added file watch at renderers: renderers\\Samsung-F5100.conf
DEBUG 2019-01-19 20:55:02.121 [main] Added file watch at renderers: renderers\\Samsung-F5505.conf
DEBUG 2019-01-19 20:55:02.122 [main] Added file watch at renderers: renderers\\Samsung-F5900.conf
DEBUG 2019-01-19 20:55:02.123 [main] Added file watch at renderers: renderers\\Samsung-GalaxyNoteTab.conf
DEBUG 2019-01-19 20:55:02.124 [main] Added file watch at renderers: renderers\\Samsung-GalaxyS5.conf
DEBUG 2019-01-19 20:55:02.124 [main] Added file watch at renderers: renderers\\Samsung-GalaxyS7.conf
DEBUG 2019-01-19 20:55:02.125 [main] Added file watch at renderers: renderers\\Samsung-H4500.conf
DEBUG 2019-01-19 20:55:02.126 [main] Added file watch at renderers: renderers\\Samsung-H6203.conf
DEBUG 2019-01-19 20:55:02.127 [main] Added file watch at renderers: renderers\\Samsung-H6400.conf
DEBUG 2019-01-19 20:55:02.128 [main] Added file watch at renderers: renderers\\Samsung-HTE3.conf
DEBUG 2019-01-19 20:55:02.128 [main] Added file watch at renderers: renderers\\Samsung-HTF4.conf
DEBUG 2019-01-19 20:55:02.130 [main] Added file watch at renderers: renderers\\Samsung-HU7000.conf
DEBUG 2019-01-19 20:55:02.131 [main] Added file watch at renderers: renderers\\Samsung-HU9000.conf
DEBUG 2019-01-19 20:55:02.131 [main] Added file watch at renderers: renderers\\Samsung-J55xx.conf
DEBUG 2019-01-19 20:55:02.132 [main] Added file watch at renderers: renderers\\Samsung-J6200.conf
DEBUG 2019-01-19 20:55:02.133 [main] Added file watch at renderers: renderers\\Samsung-JU6400.conf
DEBUG 2019-01-19 20:55:02.133 [main] Added file watch at renderers: renderers\\Samsung-Mobile.conf
DEBUG 2019-01-19 20:55:02.134 [main] Added file watch at renderers: renderers\\Samsung-NotCD.conf
DEBUG 2019-01-19 20:55:02.135 [main] Added file watch at renderers: renderers\\Samsung-PL51E490.conf
DEBUG 2019-01-19 20:55:02.136 [main] Added file watch at renderers: renderers\\Samsung-Q6.conf
DEBUG 2019-01-19 20:55:02.137 [main] Added file watch at renderers: renderers\\Samsung-Q9.conf
DEBUG 2019-01-19 20:55:02.137 [main] Added file watch at renderers: renderers\\Samsung-SMTG7400.conf
DEBUG 2019-01-19 20:55:02.138 [main] Added file watch at renderers: renderers\\Samsung-UHD.conf
DEBUG 2019-01-19 20:55:02.139 [main] Added file watch at renderers: renderers\\Samsung-WiseLink.conf
DEBUG 2019-01-19 20:55:02.140 [main] Added file watch at renderers: renderers\\Sharp-Aquos.conf
DEBUG 2019-01-19 20:55:02.140 [main] Added file watch at renderers: renderers\\Showtime3.conf
DEBUG 2019-01-19 20:55:02.141 [main] Added file watch at renderers: renderers\\Showtime4.conf
DEBUG 2019-01-19 20:55:02.142 [main] Added file watch at renderers: renderers\\Sony-Bluray.conf
DEBUG 2019-01-19 20:55:02.142 [main] Added file watch at renderers: renderers\\Sony-Bluray2013.conf
DEBUG 2019-01-19 20:55:02.150 [main] Added file watch at renderers: renderers\\Sony-Bravia4500.conf
DEBUG 2019-01-19 20:55:02.151 [main] Added file watch at renderers: renderers\\Sony-Bravia5500.conf
DEBUG 2019-01-19 20:55:02.152 [main] Added file watch at renderers: renderers\\Sony-BraviaBX305.conf
DEBUG 2019-01-19 20:55:02.152 [main] Added file watch at renderers: renderers\\Sony-BraviaEX.conf
DEBUG 2019-01-19 20:55:02.153 [main] Added file watch at renderers: renderers\\Sony-BraviaEX620.conf
DEBUG 2019-01-19 20:55:02.153 [main] Added file watch at renderers: renderers\\Sony-BraviaEX725.conf
DEBUG 2019-01-19 20:55:02.154 [main] Added file watch at renderers: renderers\\Sony-BraviaHX.conf
DEBUG 2019-01-19 20:55:02.155 [main] Added file watch at renderers: renderers\\Sony-BraviaHX75.conf
DEBUG 2019-01-19 20:55:02.155 [main] Added file watch at renderers: renderers\\Sony-BraviaNX70x.conf
DEBUG 2019-01-19 20:55:02.156 [main] Added file watch at renderers: renderers\\Sony-BraviaNX800.conf
DEBUG 2019-01-19 20:55:02.157 [main] Added file watch at renderers: renderers\\Sony-BraviaW.conf
DEBUG 2019-01-19 20:55:02.157 [main] Added file watch at renderers: renderers\\Sony-BraviaX.conf
DEBUG 2019-01-19 20:55:02.158 [main] Added file watch at renderers: renderers\\Sony-BraviaXBR.conf
DEBUG 2019-01-19 20:55:02.159 [main] Added file watch at renderers: renderers\\Sony-BraviaXD.conf
DEBUG 2019-01-19 20:55:02.160 [main] Added file watch at renderers: renderers\\Sony-HomeTheatreSystem.conf
DEBUG 2019-01-19 20:55:02.161 [main] Added file watch at renderers: renderers\\Sony-PlayStation3.conf
DEBUG 2019-01-19 20:55:02.161 [main] Added file watch at renderers: renderers\\Sony-PlayStation4.conf
DEBUG 2019-01-19 20:55:02.162 [main] Added file watch at renderers: renderers\\Sony-PlayStationVita.conf
DEBUG 2019-01-19 20:55:02.162 [main] Added file watch at renderers: renderers\\Sony-SMPN100.conf
DEBUG 2019-01-19 20:55:02.163 [main] Added file watch at renderers: renderers\\Sony-STR5800ES.conf
DEBUG 2019-01-19 20:55:02.164 [main] Added file watch at renderers: renderers\\Sony-Xperia.conf
DEBUG 2019-01-19 20:55:02.164 [main] Added file watch at renderers: renderers\\Sony-XperiaZ3.conf
DEBUG 2019-01-19 20:55:02.165 [main] Added file watch at renderers: renderers\\Technisat-S1Plus.conf
DEBUG 2019-01-19 20:55:02.166 [main] Added file watch at renderers: renderers\\Telefunken-TV.conf
DEBUG 2019-01-19 20:55:02.167 [main] Added file watch at renderers: renderers\\Telstra-Tbox.conf
DEBUG 2019-01-19 20:55:02.167 [main] Added file watch at renderers: renderers\\Thomson-U3.conf
DEBUG 2019-01-19 20:55:02.168 [main] Added file watch at renderers: renderers\\VideoWeb-VideoWebTV.conf
DEBUG 2019-01-19 20:55:02.169 [main] Added file watch at renderers: renderers\\Vizio-SmartTV.conf
DEBUG 2019-01-19 20:55:02.169 [main] Added file watch at renderers: renderers\\VLC-for-desktop.conf
DEBUG 2019-01-19 20:55:02.170 [main] Added file watch at renderers: renderers\\WesternDigital-WDTVLive.conf
DEBUG 2019-01-19 20:55:02.170 [main] Added file watch at renderers: renderers\\XBMC.conf
DEBUG 2019-01-19 20:55:02.171 [main] Added file watch at renderers: renderers\\Yamaha-RN500.conf
DEBUG 2019-01-19 20:55:02.171 [main] Added file watch at renderers: renderers\\Yamaha-RXA1010.conf
DEBUG 2019-01-19 20:55:02.172 [main] Added file watch at renderers: renderers\\Yamaha-RXA2050.conf
DEBUG 2019-01-19 20:55:02.173 [main] Added file watch at renderers: renderers\\Yamaha-RXV3900.conf
DEBUG 2019-01-19 20:55:02.173 [main] Added file watch at renderers: renderers\\Yamaha-RXV500D.conf
DEBUG 2019-01-19 20:55:02.174 [main] Added file watch at renderers: renderers\\Yamaha-RXV671.conf
INFO 2019-01-19 20:55:02.174 [main] Enabled 158 configurations, listed in order of loading priority:
INFO 2019-01-19 20:55:02.174 [main] : BubbleUPnP
INFO 2019-01-19 20:55:02.174 [main] : Chromecast
INFO 2019-01-19 20:55:02.174 [main] : Naim Mu-So
INFO 2019-01-19 20:55:02.174 [main] : Panasonic AS600
INFO 2019-01-19 20:55:02.174 [main] : Panasonic AS650
INFO 2019-01-19 20:55:02.174 [main] : Panasonic BDT220
INFO 2019-01-19 20:55:02.175 [main] : Panasonic BDT360
INFO 2019-01-19 20:55:02.175 [main] : Panasonic CX680
INFO 2019-01-19 20:55:02.175 [main] : Panasonic CX700
INFO 2019-01-19 20:55:02.175 [main] : Panasonic DX
INFO 2019-01-19 20:55:02.175 [main] : Panasonic E6
INFO 2019-01-19 20:55:02.175 [main] : Panasonic ET60
INFO 2019-01-19 20:55:02.175 [main] : Panasonic GT50
INFO 2019-01-19 20:55:02.175 [main] : Panasonic Home Theater (SC-BTT)
INFO 2019-01-19 20:55:02.175 [main] : Panasonic S60
INFO 2019-01-19 20:55:02.175 [main] : Panasonic ST60
INFO 2019-01-19 20:55:02.175 [main] : Panasonic VT60
INFO 2019-01-19 20:55:02.175 [main] : Samsung Note Tab
INFO 2019-01-19 20:55:02.175 [main] : Sony Blu-ray (2013)
INFO 2019-01-19 20:55:02.175 [main] : Sony Bravia XD/XE
INFO 2019-01-19 20:55:02.175 [main] : VLC for iOS
INFO 2019-01-19 20:55:02.175 [main] : Xperia Z3
INFO 2019-01-19 20:55:02.175 [main] : Chromecast
INFO 2019-01-19 20:55:02.175 [main] : Hisense K680
INFO 2019-01-19 20:55:02.176 [main] : LG BP550
INFO 2019-01-19 20:55:02.176 [main] : LG EG910V
INFO 2019-01-19 20:55:02.176 [main] : LG LCD TV (2014)
INFO 2019-01-19 20:55:02.176 [main] : LG LM660
INFO 2019-01-19 20:55:02.176 [main] : LG LS5700
INFO 2019-01-19 20:55:02.176 [main] : LG UB820V
INFO 2019-01-19 20:55:02.176 [main] : LG WebOS TV
INFO 2019-01-19 20:55:02.176 [main] : Onkyo TX-NR8xx
INFO 2019-01-19 20:55:02.176 [main] : Panasonic DMR
INFO 2019-01-19 20:55:02.176 [main] : Panasonic TV
INFO 2019-01-19 20:55:02.176 [main] : Samsung 8 Series
INFO 2019-01-19 20:55:02.176 [main] : Samsung 9 Series
INFO 2019-01-19 20:55:02.176 [main] : Samsung BD-C6800
INFO 2019-01-19 20:55:02.176 [main] : Samsung D6400
INFO 2019-01-19 20:55:02.176 [main] : Samsung D7000
INFO 2019-01-19 20:55:02.176 [main] : Samsung EH5300
INFO 2019-01-19 20:55:02.176 [main] : Samsung EH6070
INFO 2019-01-19 20:55:02.176 [main] : Samsung ES6100
INFO 2019-01-19 20:55:02.176 [main] : Samsung ES6575
INFO 2019-01-19 20:55:02.177 [main] : Samsung ES8000
INFO 2019-01-19 20:55:02.177 [main] : Samsung ES8005
INFO 2019-01-19 20:55:02.177 [main] : Samsung F5100
INFO 2019-01-19 20:55:02.177 [main] : Samsung F5505
INFO 2019-01-19 20:55:02.177 [main] : Samsung F5900
INFO 2019-01-19 20:55:02.177 [main] : Samsung H4500
INFO 2019-01-19 20:55:02.177 [main] : Samsung H6203
INFO 2019-01-19 20:55:02.177 [main] : Samsung H6400
INFO 2019-01-19 20:55:02.177 [main] : Samsung H6500
INFO 2019-01-19 20:55:02.177 [main] : Samsung HT-E3 Series
INFO 2019-01-19 20:55:02.177 [main] : Samsung HT-F4
INFO 2019-01-19 20:55:02.177 [main] : Samsung HU7000
INFO 2019-01-19 20:55:02.177 [main] : Samsung HU9000
INFO 2019-01-19 20:55:02.177 [main] : Samsung J55xx Series
INFO 2019-01-19 20:55:02.177 [main] : Samsung J6200
INFO 2019-01-19 20:55:02.184 [main] : Samsung JU6400
INFO 2019-01-19 20:55:02.184 [main] : Samsung LED UHD
INFO 2019-01-19 20:55:02.184 [main] : Samsung PL51E490
INFO 2019-01-19 20:55:02.184 [main] : Samsung Q6 Series
INFO 2019-01-19 20:55:02.184 [main] : Sony Bravia EX725
INFO 2019-01-19 20:55:02.184 [main] : Vizio Smart TV
INFO 2019-01-19 20:55:02.184 [main] : VLC for Apple TV
INFO 2019-01-19 20:55:02.184 [main] : VLC for iOS (iPhone 5 or older)
INFO 2019-01-19 20:55:02.184 [main] : Xbox One
INFO 2019-01-19 20:55:02.184 [main] : AirPlayer
INFO 2019-01-19 20:55:02.184 [main] : Android
INFO 2019-01-19 20:55:02.184 [main] : AnyCast
INFO 2019-01-19 20:55:02.184 [main] : Apple iPad / iPhone
INFO 2019-01-19 20:55:02.184 [main] : Azur BD
INFO 2019-01-19 20:55:02.184 [main] : BRAVIA KDL-xxNX800
INFO 2019-01-19 20:55:02.184 [main] : Bush Freeview Set Top Box
INFO 2019-01-19 20:55:02.184 [main] : D-Link DSM-510
INFO 2019-01-19 20:55:02.184 [main] : DirecTV
INFO 2019-01-19 20:55:02.185 [main] : Fetch TV
INFO 2019-01-19 20:55:02.185 [main] : Freebox
INFO 2019-01-19 20:55:02.185 [main] : Freecom MusicPal
INFO 2019-01-19 20:55:02.185 [main] : Hama IR320
INFO 2019-01-19 20:55:02.185 [main] : KalemSoft Media Player
INFO 2019-01-19 20:55:02.185 [main] : Kodi
INFO 2019-01-19 20:55:02.185 [main] : LG Blu-Ray Player
INFO 2019-01-19 20:55:02.185 [main] : LG LA6200
INFO 2019-01-19 20:55:02.185 [main] : LG LA644V
INFO 2019-01-19 20:55:02.185 [main] : LG LM620
INFO 2019-01-19 20:55:02.185 [main] : LG Smart TV Upgrader
INFO 2019-01-19 20:55:02.185 [main] : Logitech Squeezebox
INFO 2019-01-19 20:55:02.185 [main] : Miracast M806
INFO 2019-01-19 20:55:02.185 [main] : Netgear NeoTV
INFO 2019-01-19 20:55:02.185 [main] : Netgem N7700
INFO 2019-01-19 20:55:02.185 [main] : Nokia N900
INFO 2019-01-19 20:55:02.185 [main] : Onkyo TX-NR7xx
INFO 2019-01-19 20:55:02.186 [main] : OPPO BDP
INFO 2019-01-19 20:55:02.186 [main] : OPPO BDP-83
INFO 2019-01-19 20:55:02.186 [main] : Panasonic BDT
INFO 2019-01-19 20:55:02.186 [main] : Panasonic TX-L32V10E
INFO 2019-01-19 20:55:02.186 [main] : Panasonic U30Z
INFO 2019-01-19 20:55:02.186 [main] : Philips Aurea
INFO 2019-01-19 20:55:02.186 [main] : Philips PUS TV
INFO 2019-01-19 20:55:02.186 [main] : Philips TV
INFO 2019-01-19 20:55:02.186 [main] : Pioneer BDP
INFO 2019-01-19 20:55:02.186 [main] : Pioneer Kuro
INFO 2019-01-19 20:55:02.186 [main] : PlayStation 3
INFO 2019-01-19 20:55:02.186 [main] : PlayStation 4
INFO 2019-01-19 20:55:02.186 [main] : PlayStation Vita
INFO 2019-01-19 20:55:02.186 [main] : Popcorn Hour
INFO 2019-01-19 20:55:02.186 [main] : Realtek
INFO 2019-01-19 20:55:02.186 [main] : Roku 3 (NSP 3)
INFO 2019-01-19 20:55:02.186 [main] : Roku 3 (NSP 5)
INFO 2019-01-19 20:55:02.186 [main] : Roku 3 (NSP 6-7)
INFO 2019-01-19 20:55:02.186 [main] : Roku TV (NSP 8)
INFO 2019-01-19 20:55:02.186 [main] : Samsung C/D Series
INFO 2019-01-19 20:55:02.187 [main] : Samsung C6600
INFO 2019-01-19 20:55:02.187 [main] : Samsung E+ Series
INFO 2019-01-19 20:55:02.187 [main] : Samsung Galaxy S5
INFO 2019-01-19 20:55:02.187 [main] : Samsung Galaxy S7
INFO 2019-01-19 20:55:02.187 [main] : Samsung Mobile
INFO 2019-01-19 20:55:02.187 [main] : Samsung Q9 Series
INFO 2019-01-19 20:55:02.187 [main] : Samsung SMT-G7400
INFO 2019-01-19 20:55:02.187 [main] : Samsung WiseLink
INFO 2019-01-19 20:55:02.187 [main] : Sharp Aquos
INFO 2019-01-19 20:55:02.187 [main] : Showtime 3
INFO 2019-01-19 20:55:02.187 [main] : Showtime 4
INFO 2019-01-19 20:55:02.187 [main] : Sony Blu-ray
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia 4500
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia 5500
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia BX305
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia EX
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia EX620
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia HX
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia HX75
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia NX70x
INFO 2019-01-19 20:55:02.187 [main] : Sony Bravia W
INFO 2019-01-19 20:55:02.188 [main] : Sony Bravia X
INFO 2019-01-19 20:55:02.188 [main] : Sony Bravia XBR
INFO 2019-01-19 20:55:02.188 [main] : Sony Home Theatre System
INFO 2019-01-19 20:55:02.188 [main] : Sony SMP-N100
INFO 2019-01-19 20:55:02.188 [main] : Sony STR-DA5800ES
INFO 2019-01-19 20:55:02.188 [main] : Sony Xperia Z/ZL/ZQ/Z1/Z2
INFO 2019-01-19 20:55:02.188 [main] : Streamium
INFO 2019-01-19 20:55:02.188 [main] : Technisat S1+
INFO 2019-01-19 20:55:02.188 [main] : Telefunken TV
INFO 2019-01-19 20:55:02.188 [main] : Telstra T-Box
INFO 2019-01-19 20:55:02.188 [main] : Thomson U3 Series
INFO 2019-01-19 20:55:02.188 [main] : Unknown renderer
INFO 2019-01-19 20:55:02.188 [main] : VideoWeb TV
INFO 2019-01-19 20:55:02.188 [main] : VLC for desktop
INFO 2019-01-19 20:55:02.188 [main] : WD TV Live
INFO 2019-01-19 20:55:02.188 [main] : Windows Media Player
INFO 2019-01-19 20:55:02.188 [main] : XBMC
INFO 2019-01-19 20:55:02.188 [main] : Xbox 360
INFO 2019-01-19 20:55:02.188 [main] : Yamaha R-N500
INFO 2019-01-19 20:55:02.188 [main] : Yamaha RX-A1010
INFO 2019-01-19 20:55:02.189 [main] : Yamaha RX-A2050
INFO 2019-01-19 20:55:02.189 [main] : Yamaha RX-V3900
INFO 2019-01-19 20:55:02.189 [main] : Yamaha RX-V500D
INFO 2019-01-19 20:55:02.189 [main] : Yamaha RX-V671
DEBUG 2019-01-19 20:55:02.532 [main] UPNP Services are online, listening for media renderers
DEBUG 2019-01-19 20:55:02.533 [main] Attached http player control handler to web server
INFO 2019-01-19 20:55:02.533 [main] Checking the fontconfig cache in the background, this can take two minutes or so.
DEBUG 2019-01-19 20:55:02.546 [main] Starting "C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe" -hwaccels
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] ffmpeg version N-80363-g403a53c Copyright (c) 2000-2016 the FFmpeg developers
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] built with gcc 5.4.0 (GCC)
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmfx --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroedinger --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-decklink --enable-zlib
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libavutil 55. 24.100 / 55. 24.100
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libavcodec 57. 46.100 / 57. 46.100
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libavformat 57. 38.100 / 57. 38.100
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libavdevice 57. 0.101 / 57. 0.101
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-1] Hardware acceleration methods:
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-1] dxva2
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-1] qsv
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libavfilter 6. 46.101 / 6. 46.101
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libswscale 4. 1.100 / 4. 1.100
DEBUG 2019-01-19 20:55:02.598 [ffmpeg64.exe-1-2] libswresample 2. 1.100 / 2. 1.100
DEBUG 2019-01-19 20:55:02.599 [ffmpeg64.exe-1-2] libpostproc 54. 0.100 / 54. 0.100
INFO 2019-01-19 20:55:02.605 [main] Configuration saved to "C:\ProgramData\UMS\UMS.conf"
DEBUG 2019-01-19 20:55:02.605 [main] AviSynth plugins directory: C:\Program Files (x86)\AviSynth\plugins
INFO 2019-01-19 20:55:02.606 [main] VSFilter / DirectVobSub was not found. This can cause problems when trying to play subtitled videos with AviSynth.
DEBUG 2019-01-19 20:55:02.616 [cling-12] Matched media renderer "Samsung LED UHD" based on dlna details "[TV] Samsung 6 Series (65) 192.168.2.25 uuid:5fd50659-8d42-45a9-874e-0f6f38af02e0 Samsung Electronics UN65KU6491 AllShare1.0 Samsung TV DMR http://www.samsung.com/sec http://www.samsung.com/sec"
DEBUG 2019-01-19 20:55:02.617 [cling-12] Reading MediaInfo: true (default: false)
DEBUG 2019-01-19 20:55:02.618 [cling-12] Reading RendererName: "Samsung LED UHD" (default: "Unknown renderer")
DEBUG 2019-01-19 20:55:02.618 [cling-12] Adding status button for [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.619 [cling-12] Reading RendererIcon: "samsung-tv.png" (default: "unknown.png")
DEBUG 2019-01-19 20:55:02.658 [main] Checking transcoding engine AviSynth/FFmpeg
DEBUG 2019-01-19 20:55:02.663 [cling-12] New renderer found: "[TV] Samsung 6 Series (65)" with dlna details: {friendlyName=[TV] Samsung 6 Series (65), address=192.168.2.25, udn=uuid:5fd50659-8d42-45a9-874e-0f6f38af02e0, manufacturer=Samsung Electronics, modelName=UN65KU6491, modelNumber=AllShare1.0, modelDescription=Samsung TV DMR, manufacturerURL=http://www.samsung.com/sec, modelURL=http://www.samsung.com/sec}
DEBUG 2019-01-19 20:55:02.663 [cling-12] Adding device: urn:schemas-upnp-org:device:MediaRenderer:1 (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:5fd50659-8d42-45a9-874e-0f6f38af02e0, Descriptor: http://192.168.2.25:9197/dmr, Root: true
DEBUG 2019-01-19 20:55:02.663 [cling-12] Subscribing to RenderingControl service on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.664 [cling-12] Subscribing to ConnectionManager service on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.664 [cling-12] Subscribing to AVTransport service on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.664 [cling-12] Subscribing to StreamSplicing service on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.722 [cling-13] Subscription established: AVTransport on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.722 [cling-14] Subscription established: ConnectionManager on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.725 [cling-14] Subscription established: StreamSplicing on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.726 [cling-14] Subscription established: RenderingControl on [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.736 [cling-12] Created upnp player for [TV] Samsung 6 Series (65)
DEBUG 2019-01-19 20:55:02.746 [main] C:\Program Files (x86)\Universal Media Server\win32\ffmpeg64.exe supported protocols: [async, bluray, cache, concat, crypto, data, file, ftp, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtp, srtp, subfile, tcp, tls, udp, udplite, rtmp, rtmpe, rtmps, rtmpt, rtmpte, mms]
DEBUG 2019-01-19 20:55:02.813 [main] C:\Program Files\ImageMagick-7.0.8-Q16\ffmpeg.exe supported protocols: [async, bluray, cache, concat, crypto, data, ffrtmpcrypt, ffrtmphttp, file, ftp, gopher, hls, http, httpproxy, https, mmsh, mmst, pipe, rtmp, rtmpe, rtmps, rtmpt, rtmpte, rtmpts, rtp, srtp, subfile, tcp, tls, udp, udplite, mms]
INFO 2019-01-19 20:55:02.814 [main] Transcoding engine "AviSynth/FFmpeg" is available
DEBUG 2019-01-19 20:55:02.817 [main] Checking transcoding engine AviSynth/MEncoder
INFO 2019-01-19 20:55:02.852 [main] Transcoding engine "AviSynth/MEncoder" is available
DEBUG 2019-01-19 20:55:02.853 [main] Checking transcoding engine FFmpeg Audio
INFO 2019-01-19 20:55:02.853 [main] Transcoding engine "FFmpeg Audio" is available
DEBUG 2019-01-19 20:55:02.853 [main] Checking transcoding engine MEncoder Video
INFO 2019-01-19 20:55:02.853 [main] Transcoding engine "MEncoder Video" is available
DEBUG 2019-01-19 20:55:02.853 [main] Checking transcoding engine FFmpeg Video
INFO 2019-01-19 20:55:02.853 [main] Transcoding engine "FFmpeg Video" is available
DEBUG 2019-01-19 20:55:02.854 [main] Checking transcoding engine VLC Video
INFO 2019-01-19 20:55:02.854 [main] Transcoding engine "VLC Video" is available
DEBUG 2019-01-19 20:55:02.856 [main] Checking transcoding engine FFmpeg Web Video
INFO 2019-01-19 20:55:02.856 [main] Transcoding engine "FFmpeg Web Video" is available
DEBUG 2019-01-19 20:55:02.856 [main] Checking transcoding engine MEncoder Web Video
INFO 2019-01-19 20:55:02.856 [main] Transcoding engine "MEncoder Web Video" is available
DEBUG 2019-01-19 20:55:02.856 [main] Checking transcoding engine VLC Web Video
INFO 2019-01-19 20:55:02.856 [main] Transcoding engine "VLC Web Video" is available
DEBUG 2019-01-19 20:55:02.857 [main] Checking transcoding engine tsMuxeR Video
INFO 2019-01-19 20:55:02.906 [main] Transcoding engine "tsMuxeR Video" is available
DEBUG 2019-01-19 20:55:02.906 [main] Checking transcoding engine tsMuxeR Audio
INFO 2019-01-19 20:55:02.907 [main] Transcoding engine "tsMuxeR Audio" is available
DEBUG 2019-01-19 20:55:02.907 [main] Checking transcoding engine VLC Web Audio (Legacy)
INFO 2019-01-19 20:55:02.907 [main] Transcoding engine "VLC Web Audio (Legacy)" is available
DEBUG 2019-01-19 20:55:02.907 [main] Checking transcoding engine VLC Web Video (Legacy)
INFO 2019-01-19 20:55:02.907 [main] Transcoding engine "VLC Web Video (Legacy)" is available
DEBUG 2019-01-19 20:55:02.908 [main] Checking transcoding engine DCRaw
INFO 2019-01-19 20:55:02.936 [main] Transcoding engine "DCRaw" is available
DEBUG 2019-01-19 20:55:02.938 [main] Reading ffmpeg_available_gpu_acceleration_methods: "auto,dxva2,qsv" (default: "auto")
DEBUG 2019-01-19 20:55:02.950 [main] Reading avisynth_script: "<movie>
<sub>" (default: "<movie>
<sub>
INFO 2019-01-19 20:55:02.959 [main] Using address /192.168.2.18 found on network interface: name:eth3 (Intel(R) Ethernet Connection (2) I219-V)
INFO 2019-01-19 20:55:02.959 [main] Created socket: /192.168.2.18:5001
INFO 2019-01-19 20:55:02.995 [main] WEB interface is available at: http://192.168.2.18:9001
INFO 2019-01-19 20:55:03.005 [main] A tiny cache admin interface is available at: http://192.168.2.18:5001/console/home
DEBUG 2019-01-19 20:55:03.011 [main] master is internal:net.pms.dlna.RealFile str Marvels.The.Punisher.S02E05.1080p.mkv>F:\files
DEBUG 2019-01-19 20:55:03.043 [main] Added file watch at H:\here: H:\\here\\**
DEBUG 2019-01-19 20:55:03.043 [main] Added file watch at F:\files: F:\\files\\**
DEBUG 2019-01-19 20:55:03.043 [main] Added file watch at E:\cine: E:\\cine\\**
DEBUG 2019-01-19 20:55:03.065 [main] Added file watch at C:\ProgramData\UMS: C:\\ProgramData\\UMS\\WEB.conf
DEBUG 2019-01-19 20:55:03.067 [main] Sending BYEBYE...
DEBUG 2019-01-19 20:55:03.230 [cling-8] AVTransportURI:
DEBUG 2019-01-19 20:55:03.230 [cling-8] AVTransportURIMetaData:
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentMediaDuration: 0:00:00
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentPlayMode: NORMAL
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentRecordQualityMode: NOT_IMPLEMENTED
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentTrack: 0
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentTrackDuration: 0:00:00
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentTrackMetaData:
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentTrackURI:
DEBUG 2019-01-19 20:55:03.230 [cling-8] CurrentTransportActions:
DEBUG 2019-01-19 20:55:03.230 [cling-8] NextAVTransportURI:
DEBUG 2019-01-19 20:55:03.230 [cling-8] NextAVTransportURIMetaData:
DEBUG 2019-01-19 20:55:03.230 [cling-8] NumberOfTracks: 0
DEBUG 2019-01-19 20:55:03.230 [cling-8] PlaybackStorageMedium: NETWORK,NONE
DEBUG 2019-01-19 20:55:03.230 [cling-8] PossiblePlaybackStorageMedia: NETWORK,NONE
DEBUG 2019-01-19 20:55:12.547 [Get GPU acceleration methods used by FFmpeg] Stopping process: ffmpeg64.exe-1
DEBUG 2019-01-19 20:55:15.446 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:55:47.033 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:56:18.583 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:56:49.995 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:57:21.493 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:57:53.027 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:58:24.443 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:58:55.798 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:59:27.325 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 20:59:58.857 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 21:00:30.351 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 21:01:01.868 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 21:01:23.877 [HTTPv2 Request Worker 13] Matched media renderer "Windows Media Player" based on headers {Accept=text/xml, application/xml, Cache-Control=no-cache, Connection=Close, Host=192.168.2.18:5001, Pragma=no-cache, User-Agent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50}
DEBUG 2019-01-19 21:01:23.877 [HTTPv2 Request Worker 13] Reading MediaInfo: true (default: false)
DEBUG 2019-01-19 21:01:23.878 [HTTPv2 Request Worker 13] Reading RendererName: "Windows Media Player" (default: "Unknown renderer")
DEBUG 2019-01-19 21:01:23.878 [HTTPv2 Request Worker 13] Adding status button for Windows Media Player
DEBUG 2019-01-19 21:01:23.878 [HTTPv2 Request Worker 13] Reading RendererIcon: "wmp.png" (default: "unknown.png")
DEBUG 2019-01-19 21:01:23.883 [HTTPv2 Request Worker 13] Recognized media renderer "Windows Media Player"
DEBUG 2019-01-19 21:01:23.925 [HTTPv2 Request Worker 14] Recognized media renderer "Windows Media Player"
DEBUG 2019-01-19 21:01:33.311 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 21:02:04.824 [UPNP-AliveMessageSender] Sending ALIVE...
DEBUG 2019-01-19 21:02:36.383 [UPNP-AliveMessageSender] Sending ALIVE...
