Sony xe7005 problems
jps92
Re: Sony xe7005 problems
Post by jps92 »
Try deleting all the lines under "# Supported video formats:" in the Sony-BraviaXD.conf.
valib
Post by valib »
@iMik try to delete the database or make the clean install of the UMS.
jps92
Post by jps92 »
Can you do
viewtopic.php?f=9&t=556
again.
jps92
Post by jps92 »
You should add this at the end of the file for try:
Supported = f:mkv m:video/x-matroska
Supported = f:mpegps a:lpcm m:video/mpeg
Supported = f:mpegts a:lpcm|ac3 m:video/vnd.dlna.mpeg-tts
Supported = f:mp4 m:video/mp4
# Supported audio formats:
Supported = f:wav m:audio/L16
Supported = f:mp3 a:mp3 m:audio/mpeg
Supported = f:flac m:audio/flac
SupportedExternalSubtitlesFormats = ASS,SAMI,SUBRIP,MICRODVD,TEXT
If you cannot read the files mkv you remove the line "Supported = f:mkv m:video/x-matroska"
