Can't run after 7.8.0 update
Hello all,
I have had no problems with UMS up to version 7.1.0. I decided to update to version 7.8.0 and the problems began. I tried to load UMS and nothing happens. I have tried installing Java 8_201 both x32 and x64 versions and the same result. I also tried to install the standalone version with same result. Now I have been playing around with Java 8_201, UMS 7.8.0 and the x64 wrapper 3.5.37 as I think the problems have all been Java related. My line of thinking has come from running wrapper.exe to see what the output is. A lot of the time it was reporting the 32bit wrapper doesn't like x64bit Java, fair enough, so I used the x64 bit wrapper. Now I get this output:
STATUS | wrapper | 2019/01/31 17:55:01 | --> Wrapper Started as Console
STATUS | wrapper | 2019/01/31 17:55:01 | Java Service Wrapper Community Edition 64-bit 3.5.37
STATUS | wrapper | 2019/01/31 17:55:01 | Copyright (C) 1999-2018 Tanuki Software, Ltd. All Rights Reserved.
STATUS | wrapper | 2019/01/31 17:55:01 | http://wrapper.tanukisoftware.com
STATUS | wrapper | 2019/01/31 17:55:01 | Launching a JVM...
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager: Initializing...
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperSimpleApp Error: Unable to locate the class net.pms.PMS : java.lang.ClassNotFoundException: net.pms.PMS
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperSimpleApp Usage:
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: Error in WrapperListener.start callback. java.lang.IllegalArgumentException: can't parse argument number: app_class{/app_method}
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: java.lang.IllegalArgumentException: can't parse argument number: app_class{/app_method}
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.text.MessageFormat.makeFormat(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.text.MessageFormat.applyPattern(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.text.MessageFormat.<init>(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.text.MessageFormat.format(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at org.tanukisoftware.wrapper.WrapperResources.getString(WrapperResources.java:215)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.showUsage(WrapperSimpleApp.java:621)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at org.tanukisoftware.wrapper.WrapperSimpleApp.start(WrapperSimpleApp.java:465)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at org.tanukisoftware.wrapper.WrapperManager$10.run(WrapperManager.java:4429)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: Caused by: java.lang.NumberFormatException: For input string: "app_class{/app_method}"
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.lang.NumberFormatException.forInputString(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: at java.lang.Integer.parseInt(Unknown Source)
INFO | jvm 1 | 2019/01/31 17:55:01 | WrapperManager Error: ... 8 more
STATUS | wrapper | 2019/01/31 17:55:03 | <-- Wrapper Stopped
Can anyone point me in the right direction so I can enjoy UMS again? Oh, I am running Windows 10 Pro x64.
Thanks in advance.
Thanks in advance.
