VLC
sparker781
VLC
Post by sparker781 » Mon Nov 25, 2013 1:50 am
I am trying to setup UMS 3.10 in conjunction with VLC to play streaming videos from my PS3...I went thru the mini guide in the help tab however after setting it as outlined and i saved and restarted UMS I get a no renderers found.
Any help is extemely appreciated.
Re: VLC
Post by SubJunk » Mon Nov 25, 2013 4:34 pm
Unfortunately our Help tab isn't the best, I probably need to either update or remove it... Anyway is there any reason for wanting to use VLC? It's not very stable for our purposes so it would be better to use the default engines
sparker781
Re: VLC
Post by sparker781 » Wed Nov 27, 2013 4:50 am
I just use VLC on my PC for playing video files and figured it would be just as good for using it thru UNS...if you recommend I not use it I will keep the default engines.
thanks
