tsMuxeR not being used?
Re: tsMuxeR not being used?
That did the trick! May I ask what was the final issue, as you partially fixed it on your first try?
Thanks for all your hard work!
You're welcome
There were two issues - the first one was that tsMuxeR was only being used if the input file had AC-3 or DTS audio, and the second issue was that in the "Expert Settings" popup in the MEncoder options, there was a condition that stated to not mux (-nomux) if the source is MKV at 29.97FPS, so I removed that condition. I suspect it's an ancient workaround for a MEncoder bug that was fixed.
