"Cannot play media" on PS4 after pausing or tracking ?
I used UMS with the PS4 Media Player. Videos play fine, however, I did notice when pausing a video, after trying to play again the video usually errors our saying "Media cannot be played." At this point I can play the video again from the menu and it will either start from the beginning or the part where I left off. If I have to start from the beginning, I can usually track to where I was in the video, but it either gives the same "media cannot be played" message or if it does play the video it is super choppy and laggy for a few seconds. I primarily use .mkv files.
Any thoughts on what the cause might be and how to fix it? I'm also running on some older hardware so that could be the culprit, but I want to see if there are any settings I could change or something wrong with my set up before I consider investing in newer hardware.
Thank you!
Thank you!
Re: "Cannot play media" on PS4 after pausing or tracking ?
This is unrelated to your hardware - UMS has several independent bugs related to pause/resume functionality.
I'm getting Deja Vu again https://www.universalmediaserver.com/fo ... =9&t=13933
Bye
Bye
