[Solved] UMS wont run as a service
Re: Windows Service on version 9.6.1 and 9.6.2 not Work
SubJunk wrote: ↑Fri Jun 19, 2020 9:49 am Could you please try 9.6.0 to help narrow this down? https://sourceforge.net/projects/unimed ... e/download
I'm not sure if updating to the service wrapper would help. It would be good to know if that works though for unrelated reasons
hello SubJunk, I tested Version 9.6.0 and 9.7.0 and I have the same problem.
The Windows Service does not start.
I also tried the Wrapper of the page you listed, the community and standard versions did not work.
Only Version 9.5.0 remains stable ...
Re: UMS wont run as a service
hello SubJunk, as I wrote to you in the other post, it seems that the Windows service only works up to version 9.5.0. other versions from 9.6.0 seems to have a problem ...SubJunk wrote: ↑Sat Jun 20, 2020 5:04 pm Would you please try with a previous version, https://sourceforge.net/projects/unimed ... e/download ?
There is another support thread where a user has said this is a new problem, that the service worked with 9.5.0, so you may want to try that version too. Please let us know if it works with 9.6.0 or 9.5.0
I just tried 9.7.0 (since UMS offered me to upgrade first), then 9.6.0, then 9.5.0 (with a reboot between each version after removing it, setting up as a service ans remove it again, tried login the user info in the 9.5.0 attempt and still nothing... pffff, which version of linux do you recomend? Im considering migrating soooo hard
Regarding UMS, everything is more painful on Linux. The reason is that the "primary audience" is using Windows. There is no solution to run UMS as a daemon on Linux without scripting it yourself.
OMG I thought I replied already, I tried first with 9.7.0 since UMS oofered me to upgrade, it didnt work, then removed, rebooted, installed, configured as service, rebooted, it didnt work, repeated the same process with 9.5.0 and even added admin user details to the service, still failed, what Linux distro do you recomend? Im kind of tired lol
I would say just stick with 9.5.0 until we fix the issue, I will post here when I fix it. I'll work on it tonight.
I just tried and it works for me after installing as service on 9.7.0 but I'm trying to redo the test by doing 9.5.0 first and then 9.7.0
It's still working for me. The exact steps I have done:
1) Removed previous service by running sc delete "Universal Media Server" in cmd
2) Installed 9.5.0
3) Run 9.5.0
4) Installed as service
5) Quit the GUI
6) Started the service
7) Confirmed it works via web interface
8) Stopped service
9) Installed 9.7.0 without starting the GUI
10) Started the service
11) Confirmed it still works via web interface
Can you please let me know if you do these steps when you upgrade or do you do it differently?
2) Installed 9.5.0
3) Run 9.5.0
5) Quit the GUI
8) Stopped service
I have a test build for you that changes the way the program and installer handle services: https://www.universalmediaserver.com/up ... taller.exe
In that test build, the installer now:
1) stops the existing service if it is running
2) starts the service again if the checkbox is enabled at the end
In addition, it adds a prompt to UMS itself that warns about using it as a GUI when it is already installed as a service
Sorry for the spam but I have made another test file with more improvements. It works for me but I don't know if it fixes this problem you have since I can't reproduce that. Please try it: https://www.universalmediaserver.com/up ... ller-2.exe
The changes are:
- The installer stops the existing service if it is running
- The installer starts the service if the checkbox is enabled at the end and the service is installed, instead of starting the GUI
- The installer does not try to start the GUI on computer startup if the service is installed
- The program GUI warns about using it as a GUI when it is already installed as a service
- The service uses our bundled Java instead of the system one
The changes are:
