Pioneer BDP 140 problem
Good evening, does anyone know how to run UMS with a Pioneer BDP 140?
files sopcaste are seen but will not start. The player says FILE NOT RECOGNIZED.
UMS me a strange thing the reader sees as a pioneer NETGEAR GEO TV. here is the screen:
how can I fix it?
THANK YOU
how can I fix it?
THANK YOU
Re: Pioneer BDP 140 problem
Hi, it means that both devices use the same User-Agent string to register itself to UMS.
In the standard UMS release there is no renderer file defined for your Pioneer BDP.
So you have to make it yourself and put that in the UMS renrers directory.
You can read how to do so in the Renderers section.
viewforum.php?f=5
viewforum.php?f=5
thanks I posted in that section.
