[Solved] 3.4.0 issue vanishing off ps3
Gareee
Post by Gareee »
UMS starts up fine on the ps3 and works fine, but disappears from the ps3 after a time, and needs to be manually restarted to show up again.
Only other issue I see is no update on the status panel while streaming.. I see 0 bitrate being transferred, and a peak of 63 regardless of file type of resolution being streamed.
3.4.0 was installed clean, and log attached.
Quick question.. I have over 100 meg wireless network here.. I just selected wireless in the install options. should I have selected something else?
log attached
(50.03 KiB) Downloaded 531 times
Gareee
Re: 3.4.0 issue vanishing off ps3
Post by Gareee »
Still seeing this with 3.4.1 installed on top of 3.4.0
I have a feeling it has something to do with the setup wizard. If I install 3.2.0 over the top, I get the same issue, but if I install 3.2.0 in a clean folder, it stops happening.
I'm trying a clean install in a empty folder to see if that resolves the issue.
Gareee
Post by Gareee »
I can confirm that a emptied folder clean install of 3.4.1 cured the vanishing off ps3 manual restart issue.
Thanks for updating us :)
