[Solved] no audio on the panasonic on iso file
nightly build 4.41
- ums_dbg4.41.zip
- no audio on iso
- (169.35 KiB) Downloaded 381 times
Re: no audio on the panasonic on iso file
Does it work if you replace mencoder.exe with the one from 4.3.1?
yes it does.
I am curious does iso work for people with other renders?
No, I can't get sound from dvd iso files on ps3 on 4.4.0 either.... it worked on 4.3.1.
I've confirmed the bug now, thanks guys. I'm working on a fix now
Using 4.3.1's mencoder fixed the issue where I got No Audio with any DVDISO to PS3 but even still I have some that have the issue.
Re: [Solved] no audio on the panasonic on iso file
It's fixed in the next release. jeisurii please let me know how it goes when you upgrade
I rebuild off the master branch it works now.
Now the only problems I have is the onion video stream ,engadget audio stream and display of gif images
Rebuilt off Master, installed. Verified fixed for any DVDISO (tried a Gamera disc I had, works great), tried my troublesome Transformers Galaxy Force ISO and still doesn't work. The DVD has just a single AC3 2.0 track. Also, even going into Transcode folder I am unable to browse down to the Title 1 folder. It doesn't go any further. Attached dbg.
- (36.08 KiB) Downloaded 412 times
glad you said that most of my iso work with audio.
There is the one i didn't check beach blanket bingo still no audio
uploading the debug
uploading the debug
- no audio on beach blanket bingo
- (109.57 KiB) Downloaded 396 times
