Can't play videos on PS3 after 5.1.1
I'm getting "The data is corrupted" when trying to play videos on the PS3 after upgrading to 5.1.1.
I attached the debug files as requested.
Edit: I downgraded to 5.1.0 and it works fine, so there seems to be a problem with 5.1.1...
- (36.56 KiB) Downloaded 400 times
Re: Can't play files on PS3 after 5.1.1
I just wanted to state that my PS3 plays my music (all apple lossless) and is showing my images again (jpg's) without issue. Have not tried any videos yet. Maybe you should try a clean install and see if that helps.
Re: Can't play videos on PS3 after 5.1.1
I just tested files on my PS3 and they worked same as always. I do see an error listed in your logs, but unfortunately you changed the debug level to TRACE after starting to play the file. Please change it to trace as soon as you start the program, then reproduce the problem, then post the logs
Thanks, will do after I get back home. I'm currently traveling for a week.SubJunk wrote:I just tested files on my PS3 and they worked same as always. I do see an error listed in your logs, but unfortunately you changed the debug level to TRACE after starting to play the file. Please change it to trace as soon as you start the program, then reproduce the problem, then post the logs
OK so I updated to 5.1.2 and everything seems to be working fine now...
