PS4 now support DLNA!
oxishmit
Re: PS4 now support DLNA!
Post by oxishmit » Mon Nov 02, 2015 12:44 pm
AuthenticM wrote:I have to put files I want to stream on my computer's desktop. If they're too deep inside folders (the path name being too long) then I'll get an "unreadable media" error. This is weird.
Long Path Tool can fix this problem try it.
emoolaf
Post by emoolaf » Thu Nov 19, 2015 2:52 am
hey, will there be an update soon, which fixes the dts problem?
those 1080 mkv´s with dts sound wont play the audio when I chose "no encoding"
it plays the sound when I chose the encoded version, but then its not skippable?
emoolaf
Post by emoolaf » Sun Nov 22, 2015 8:58 am
cant nobody help?
it worked some versions before??
cant play any mkv´s anymore properly
Lasher
Post by Lasher » Mon Nov 23, 2015 4:20 pm
if it worked on previous versions then go back to the one that worked for now ... hopefully it might work still...I think sony may have altered their media player which may have caused issues with UMS.
we can only see if the devs come back and alter the coding so it will work again.
emoolaf
Post by emoolaf » Mon Nov 23, 2015 11:11 pm
edit: ok older versions dont work either...sony f**ked up
Lasher
Post by Lasher » Sat Nov 28, 2015 3:32 am
guess we have to wait for someone to fix it
emoolaf
Post by emoolaf » Mon Nov 30, 2015 6:30 pm
ps4 media player had an update, gonna try if it heleped somehow
Lasher
Post by Lasher » Thu Dec 03, 2015 2:59 am
emoolaf wrote:ps4 media player had an update, gonna try if it heleped somehow
Let us know how you go with the new version
emoolaf
Post by emoolaf » Thu Dec 03, 2015 4:05 am
sry i forgot...for sure nothing changed
DTS sound cant be played with "no transcoding" and still no fast forward with transcoding but with sound
Lasher
Post by Lasher » Sat Dec 05, 2015 3:17 am
emoolaf wrote:sry i forgot...for sure nothing changed
doesnt seem to have been any posts in here for awhile from the devs and updating UMS for PS4 ... maybe they are busy with other parts of the project or sony changed something that cant be fixed as of yet.
we'll just have to be patient and hopefully it will get sorted out :)
