Media Server appears on PS3, but "No Renderers Found"
Hi all, I've been lurking for a little while and have learned quite a bit from all the info on the forums. It has been such a great resource to get me up and running, however I've recently come across an issue that I just can't figure out.
The Universal Media server appears as expected on the PS3 when I turn it on, and streams my videos flawlessly (as far as I can tell), and decodes the audio tracks correctly, however, when checking the settings on my PC, the program shows there are "No Renderers Found". Odd, especially considering I'm streaming a movie at the same time.
So, why am I complaining? I can't seem to change any settings in the program, or have it discover my iTunes library as I would expect it to. It also requires a full PS3 and CPU restart to discover new folders and videos (this may be working as designed though, I'm not sure).
Here's the code from the debug log:
INFO 2012-11-21 09:10:36.416 [main] Starting Universal Media Server 2.0.0
INFO 2012-11-21 09:10:36.431 [main] Based on PS3 Media Server by shagrath, copyright 2008-2012
INFO 2012-11-21 09:10:36.431 [main] http://www.universalmediaserver.com
INFO 2012-11-21 09:10:36.431 [main] Build: 9456e1544 (2012-10-31)
INFO 2012-11-21 09:10:36.431 [main] Java: 1.7.0_09-Oracle Corporation
INFO 2012-11-21 09:10:36.431 [main] OS: Windows 7 64-bit 6.1
INFO 2012-11-21 09:10:36.431 [main] Encoding: UTF-8
INFO 2012-11-21 09:10:36.431 [main] Memory: 1113 MB
INFO 2012-11-21 09:10:36.431 [main] Working directory: C:\Program Files (x86)\Universal Media Server
INFO 2012-11-21 09:10:36.447 [main] Temp directory: C:\Users\Fellipe\AppData\Local\Temp\universalmediaserver
INFO 2012-11-21 09:10:36.447 [main] Logging config file: C:\Program Files (x86)\Universal Media Server\logback.xml
INFO 2012-11-21 09:10:36.447 [main] debug.log: C:\Users\Fellipe\AppData\Local\Temp\\debug.log
INFO 2012-11-21 09:10:36.447 [main] Profile directory: C:\ProgramData\UMS
INFO 2012-11-21 09:10:36.447 [main] Profile path: C:\ProgramData\UMS\UMS.conf
INFO 2012-11-21 09:10:36.447 [main] Profile permissions: rw
INFO 2012-11-21 09:10:36.447 [main] Profile name: HP-SLIM
INFO 2012-11-21 09:10:36.447 [main] Loading MediaInfo library
INFO 2012-11-21 09:10:36.540 [main] Loaded MediaInfoLib - v0.7.61
INFO 2012-11-21 09:10:36.540 [main] Loading renderer configurations from C:\Program Files (x86)\Universal Media Server\renderers
INFO 2012-11-21 09:10:36.540 [main] Loading configuration file: AirPlayer.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: Android.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: Bravia4500.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: Bravia5500.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: BraviaEX.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: DirecTVHR.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: DLinkDSM510.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: FreeboxHD.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: FreecomMusicPal.conf
INFO 2012-11-21 09:10:36.556 [main] Loading configuration file: iPad-iPhone.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: Kuro.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: LGST600.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: N900.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: OPPOBDP83.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: OPPOBDP93.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: Panasonic.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: Philips.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: PhilipsPFL.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: PopcornHour.conf
INFO 2012-11-21 09:10:36.572 [main] Loading configuration file: PS3.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: Realtek.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: Samsung-SMT-G7400.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: SamsungAllShare.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: SamsungWiseLink.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: Showtime3.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: SMP-N100.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: SonyBluray.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: SonyBraviaHX800.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: Streamium.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: WDTVLive.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: WMP.conf
INFO 2012-11-21 09:10:36.587 [main] Loading configuration file: XBMC.conf
INFO 2012-11-21 09:10:36.603 [main] Loading configuration file: XBOX360.conf
INFO 2012-11-21 09:10:36.603 [main] Loading configuration file: YamahaRXA1010.conf
INFO 2012-11-21 09:10:36.603 [main] Loading configuration file: YamahaRXV671.conf
INFO 2012-11-21 09:10:36.603 [main] Checking MPlayer font cache. It can take a minute or so.
INFO 2012-11-21 09:10:36.839 [main] Done!
INFO 2012-11-21 09:10:36.839 [main] Found AviSynth plugins dir: C:\Program Files (x86)\AviSynth\plugins
INFO 2012-11-21 09:10:36.839 [main] VSFilter.dll is not in the AviSynth plugins directory. This can cause problems when trying to play subtitled videos with AviSynth
INFO 2012-11-21 09:10:36.839 [main] Searching for plugins in C:\Program Files (x86)\Universal Media Server\plugins
INFO 2012-11-21 09:10:36.839 [main] No plugins found
INFO 2012-11-21 09:10:36.854 [main] Registering transcoding engine: AviSynth/FFmpeg
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: FFmpeg Audio
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: MEncoder
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: AviSynth/MEncoder
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: MPlayer Audio
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: FFmpeg Web Video
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: MEncoder Web
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: MPlayer Video Dump
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: MPlayer Web
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: tsMuxeR
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: Audio High Fidelity
INFO 2012-11-21 09:10:36.870 [main] Executable of transcoder profile VLC Audio Streaming not found
INFO 2012-11-21 09:10:36.870 [main] Executable of transcoder profile VLC Video Streaming not found
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: FFmpeg DVR-MS Remux
INFO 2012-11-21 09:10:36.870 [main] Registering transcoding engine: dcraw Thumbnailer
INFO 2012-11-21 09:10:36.979 [main] Using address /192.168.2.100 found on network interface: name:eth3 (Realtek PCIe GBE Family Controller)
INFO 2012-11-21 09:10:36.979 [main] Created socket: /192.168.2.100:5001
INFO 2012-11-21 09:10:36.995 [HTTP Server] Starting DLNA Server on host 192.168.2.100 and port 5001...
INFO 2012-11-21 09:10:36.995 [main] Checking shared folder: F:\Filmes
INFO 2012-11-21 09:10:37.057 [main] Using the following UUID configured in UMS.conf: a0a7c5d8-a6d1-316d-9e7b-2a7a184725c5
INFO 2012-11-21 09:10:39.554 [main] The server should now appear on your renderer
INFO 2012-11-21 09:24:18.295 [UPNPHelper] No IP filter specified, access granted to /192.168.2.100
I'm running Win7 64bit, blah blah blah...I don't think this matters because the actual playback is just about perfect. It's probably worth noting that the last time it found a render was about a week ago, but nothing since. The settings that I configured then, is what has stuck, even after trying to change the settings in the setup menu.
So, I'd appreciate any insight you guys might have. I've ran through the network configurations (seems right, since it streams at all), the setup guides, and countless threads that seemed CLOSE to the issue I'm having, but nothing that seems to have helped.
Thanks in advance for any help you guys can provide.
- SharkHunter
- Developer
Re: Media Server appears on PS3, but "No Renderers Found"
Have you looked into the task manager to ensure you don't have another UMS running that actually is serving your video? It could be that you have 2 UMS running and then changes you make will have really no effect. So quit UMS. Look in the task manager and make sure no "javaw.exe" process still lurks around and then restart UMS.
