Some problems..
squadjot
Some problems..
Post by squadjot »
Edited: particular topics in this post is fixed
logs.rar
(17.06 KiB) Downloaded 915 times
squadjot
Re: Some problems..
Post by squadjot »
Just tried reinstalling Java, still the same...
Tried shutting off microsoft firewall/security essentials... everything is micorsoft vanilla..
No one else experiencing this.?. pack debug files just works for everyone?.. javaw doesnt hang?
squadjot
Re: Some problems..
Post by squadjot »
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding channels\channel.log
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding C:\Program Files\Universal Media Server\channels\channel.log
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding extras\channels\channel.log
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding C:\Program Files\Universal Media Server\extras\channels\channel.log
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding C:\ProgramData\UMS\WEB.conf
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding C:\ProgramData\UMS\UMS.conf
DEBUG 2012-11-27 02:10:46.423 [AWT-EventQueue-0] adding C:\Program Files\Universal Media Server\debug.log
DEBUG 2012-11-27 02:10:52.959 [AWT-EventQueue-0] packing C:\Program Files\Universal Media Server\channels\channel.log
DEBUG 2012-11-27 02:10:52.975 [AWT-EventQueue-0] packing C:\Program Files\Universal Media Server\extras\channels\channel.log
DEBUG 2012-11-27 02:10:52.975 [AWT-EventQueue-0] error packing zip file java.util.zip.ZipException: duplicate entry: channel.log
INFO 2012-11-27 02:11:04.878 [PMS Listeners Stopper] Sending BYEBYE...
DEBUG 2012-11-27 02:11:08.475 [PMS Listeners Stopper] Forcing shutdown of all active processes
INFO 2012-11-27 02:11:08.475 [PMS Listeners Stopper] Stopping server on host 192.168.1.12 and port 5001...
Ok, for some reason the zip packing breaks because of some duplicate log file channel.log
I guess if i delete that file manually, it will work..
Another problem i noticed playing a m4v with srt subtitles..the subtitles didnt load.
debug.zip
(5.86 KiB) Downloaded 1144 times
squadjot
Re: Some problems..
Post by squadjot »
Ok, about the subtitles not loading with that m4v.
If i go transocde folder, and choose "mencoder [Subrip/Undetermined]" it works.. (the subtitles are shown)
but there's also another option; "mencoder [Timed Text (TXG3)]" if i choose that one, the subs does not play..so maybe UMS thinks it's "timed text"? (what ever that is)
I did do a rebuild of the srt incase of it having invalid structure.. but the same, and everything seems ok with the subtitle file.
EDIT: And yes, the removing the duplicate channel.log file, made "pack debug files" work again
squadjot
Re: Some problems..
Post by squadjot »
Ok, some progress, i tried deleting UMS.conf, and startup using default settings.
Now javaw does not hang! YAY - , and the xvid file mentioned in the first post, now plays! (alltho has great pixelation at some points (errors), and i know it played flawless once)
I'm pretty sure i did a total uninstall/reinstall of UMS thos.. so i thought that would totally delete any config files.
Still, It didnt fix the subtitle problem.
squadjot
Re: Some problems..
Post by squadjot »
Just FYI, subtitle problem still with 2.1.2
Berzerk
Re: Some problems..
Post by Berzerk »
... and still with 2.2.0...
squadjot
Re: Some problems..
Post by squadjot »
Nope =), also the first thing i wanted to test.. still does not work.
I tells right form the start cause it shows "00:00:00.00" in subtitles area.. and from then on nothing happens subtitle-wise
